Home > Help Needed / General Tech Chat > C/R VS MAX BOOST ?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
looking into the complexly of static cylinder pressure and the affects of boosting
what should i call the max affective cylinder pressure? 250psi on cast iron head and block?
looking for a low C/R high BOOST build so was thinking 7:1 with 30psi boost giving 210psi in the cylinders given no losses and cam choice valve timing stuff not conceded lol
what do some of you much more experienced guys/girls think and advise
planing on a track/sprint car that will be road reg (weekend toy when i have time to go for a blast) im happy to have a pig off boost ill just keep the thing moving to stay on boost lol most of the time you only start the car from standing still once in a race..
from what ive read and under stood? there is no point in saying i have x sweped volume and x non sweped = said CR as the cam plays a big part in the real CR
that said how do i find the affective (true) CR of a motor and cam combo?
after that how do i then find the max boost i can add with out doing damage given 98 octain fuel?
8.21cr
25psi was max without wi
Most i succesfully ran with wi was 28psi
I had shot for 35psi but couldnt get enough fuel in there
My figures seem to back up your 7:1cr / 30psi goal
You say that you can just keep it "on boost" - well, I doubt that would be achievable on a lot of tracks. It doesn't even matter if you had a low-inertia turbo, 7:1 is really low and will take a lot of effort to keep it on-boost when cornering, when your concentration would best be applied to, well, cornering...
If you just want to be overtaken on corners, only to blast past someone on the straightaway, then be overtaken out of corner again, then what you are proposing will probbly be a lot of fun and really cool. I think it'll get boring pretty quickly though.
An engine dyno or a rolling road dyno is a good start. And a turbo that is matched to deliver the "boost" (or torque or hp) that meets your requirements.
Edited by turbodave16v on 21st Jun, 2013.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
brett what cam did you have at the time also how much displacement also you say you couldn't get enough fuel in was that efi or carb (HIF44)
dave the work truck is a turbo disel it donent come on bost till 2500 and all in about 3000 kinder like the metro chalange t3 on an 1150cc as you say its a pain in the ass to keep on boost in the corners and when your just cruseing and stab the gass it just dosent go till 2.5-3k but when it gets some bost its pulling hard so i think i might move up in CR to say 7.5-8.25: to gain some dirveablity im sure the long stroke will help the boost spool also some good maniflods etc i plan to build the motor as tough as i can then boost it to the max
safely..
the yellow book only has NA info on CR vs cam so is it right to think that my cam of choi ce 247 has only 124degrese to get stadic compresion so how do i go about working out a cylender presure at a said CR to find therical max boost lol or do you guys jut build it turn it up till it knocks then back it off a touch?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
or find some aviation fuel and just go nuts lol
If it is a track car, then simply aiming for max boost is just silly, unless you're the guy with the sequential 6speed gearbox. 4 speeds...you'll drop off the power more easily.
With good intercooling, fuel/spark control and a sensible setup you'll have a much wider power band and still be able to make lots of power. Far more than any current 4 speed box can handle even at an 8.x CR
So can you address the gearbox/traction/clutch/diff issues that go with huge boost which may lead to lots of power/torque ? Especially in a track environment ?
Or exactly what sort of power are you aiming for ? if it's just a high rpm screamer you want, that can be addressed more with camshaft and turbo choice, than low CR.
Kc500 cam 1293cc it was on hif 44
Fuel flow to the carb was enough i think the restriction it was the needle valve ( the one the float opens/closes)i never really investigated it, i had no measurable power gain with more boost anyway
Mine engine maybe due to the solid top steady and no sound deadning was very audioble in knock and some home made detcans i was getting good results
We was testing this on 2 very similar spec engines although one lost a turbo and got split
I had some quite decent datalogging gear on mine too so everything could be reviewed and tweeked off car
Lowering the CR into the 7s is a MASSIVE compromise over the overall characteristics of the engine. You'll find it gutless at the bottom end and will restrict the power band to a narrower area (where boost comes in). Going for a smaller turbo to reduce lag, will result in more power lower end, but it may not have enough flow for higher boost at the top end.
If you're aim is high boost, then you need to be looking at an efficient turbo at high boost, and a very effective intercooler setup to keep the inlet temps down. If it were me I'd be looking at keeping the CR at no lower than around 8.4:1 and if det is an issue at your desired boost and its a track car then water injection would be my next route. If you spec the engine right then high boost isn't needed for high power as robert has proved. *wink*
Edited by matty on 22nd Jun, 2013.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
sounds like im being silly in thinking low cr high boost would be a good setup for anything more than fooling around in..
how dose WI work i have never looked into it as i thought id never run a track car lol is if a function in MS3X like an injector but it sprays water in the port? or is it to do with the IC
Ms3x can control it like fuel injection have a search on here i have posted some links in the past
