| Home > Technical Chat > Turbo piston fitment | |||||||
11 Posts Member #: 10489 Member Camberley |
22nd Jun, 2013 at 07:52:18pm
Hi
22nd Jun, 2013 at 08:57:06pm
either way you cant get them wrong, as the rods dont line up with the crank
22nd Jun, 2013 at 09:10:06pm
i can get them all pointing to the left or the wright though cant i, i know they have to miss the crank webs |
22nd Jun, 2013 at 09:18:27pm
you will soon work it out ....... dont rush and remember ........ YOU ONLY GET BABIES IF YOU RUSH!
22nd Jun, 2013 at 09:54:53pm
Thanks Benross, if anybody has any tech data about the direction the A points that would be very helpful as I can't find anything. |
22nd Jun, 2013 at 10:00:45pm
If the pistons haven't been off the rods, then you will be working from them.
22nd Jun, 2013 at 10:17:30pm
Yep not a problem when the pistons are symmetrical but could be if they are slipper pistons. However I do believe the A or B is usually read from the 'front' of the engine which would be the timing gear end if that helps. If something is worth doing, it's worth doing half of. |
22nd Jun, 2013 at 10:31:15pm
If you marked the pistons, and put them in in order, they will only go in one way. You cannot get it wrong
23rd Jun, 2013 at 08:31:56am
Thanks, that's a great help |
