| Home > Help Needed / General Tech Chat > Clutch | |||||||
![]() 71 Posts Member #: 529 Advanced Member Stoke-On-Trent |
5th Jul, 2005 at 08:49:07pm
I need to change the clutch, and wanted some opinions on what to use. |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
5th Jul, 2005 at 08:56:51pm
think most of us are using pre-verto. What spring are you using?
5th Jul, 2005 at 09:20:44pm
The stock 'turbo' verto clutch should be good for 25lb ft or so over stock... Try fitting the AP race/rally plate and see what it's like. Otherwise, it's a grey all the way! On 17th Nov, 2014 Tom Fenton said:
6th Jul, 2005 at 02:20:10pm
On 05/07/2005 20:56:51 Mike said:
What spring are you using? What do you mean by this? |
6th Jul, 2005 at 02:21:55pm
On 05/07/2005 21:20:44 TurboDave said:
The stock 'turbo' verto clutch should be good for 25lb ft or so over stock... Try fitting the AP race/rally plate and see what it's like. Otherwise, it's a grey all the way! Think im gonna change to pre verto, what plate would i use with a grey? Thanks for the advice |
6th Jul, 2005 at 06:38:22pm
AP race rally plate and grey diaphram -MINI CLUBMAN 1380 TURBO- |
6th Jul, 2005 at 08:33:40pm
Where is the best place to get a standard verto turbo clutch my local place only do exchange units. |
7th Jul, 2005 at 10:01:45pm
is there any reason why you cant swap from a verto clutch to a pre verto clutch?? |
7th Jul, 2005 at 10:10:24pm
7th Jul, 2005 at 11:20:04pm
Made the descision brought a grey and race rally plate, and all the bits to do the conversion so will be ready for avon |
7th Jul, 2005 at 11:45:18pm
whereabouts did you order your plate from dude and how much did it sting you if you dont mind me asking. i need to order one when i get paid. On 20th Oct, 2015 Tom Fenton said:
9th Jul, 2005 at 10:40:28am
Brought it local from mini mine, i think it was about £40, i brought it with a load of other stuff so can't remember exact. |
9th Jul, 2005 at 12:23:12pm
cool, will keep them in mind. only up the M6 a bit for me. On 20th Oct, 2015 Tom Fenton said:
9th Jul, 2005 at 01:59:20pm
for some of you are intrested stuart at
11th Jul, 2005 at 09:42:54pm
what else is needed apart from tthe plate and cover?? i have a flywheel and back plate. Do i need any more of the flat shims other than the ones on a standard pre verto clutch??
169 Posts Member #: 748 Advanced Member Cirencester, Gloucestershire |
10th Jan, 2006 at 07:05:53pm
Just wondering if a tuned 1293 T" turbo set up would be enough for a grey/orange verto setup or am i looking at a paddle clutch assembly? suppose it depends on the boost? 1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
