| Home > Help Needed / General Tech Chat > Occasional misfire. | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
23rd Jun, 2013 at 08:30:00am
Another of those annoying problems.On a run in town,ie light load,low rpm,I get a sudden momentary loss of ignition/loss of tacho feed.Running megajolt,swopped out all the usual suspect components.Doesn't happen under real power but still not good.Why would an apparent electrical problem be load sensitive?Any thoughts,comments,jokes welcome. 'Where does the engine go?' |
23rd Jun, 2013 at 09:34:10am
Hmmm usualy the load sensitive misfires or breaking down of the coil packs would start to fail a higher loads
Yes i moved to the darkside |
23rd Jun, 2013 at 09:35:52am
Main live, to All Electrics a touch loose Steve recheck.
23rd Jun, 2013 at 11:23:34am
I had a very similar problem some while ago - your comment of the loss of tacho feed alerted me, rather than the ignition cutting out.
23rd Jun, 2013 at 06:33:50pm
Ok,thanks guys,gives me a to do list,I'll report back in due course. 'Where does the engine go?' |
23rd Jun, 2013 at 06:34:54pm
The only suggestion I have is to run it at full chat at all times. No low load use, so no misfire. On 11th Feb, 2015 robert said:
23rd Jun, 2013 at 07:35:18pm
Sounds sensible to me. |
23rd Jun, 2013 at 09:28:17pm
Knew I could rely on a tyke to come up with that one (speaking as a yellowbelly born and bred) 'Where does the engine go?' |
24th Jun, 2013 at 07:04:00am
25th Jun, 2013 at 04:35:27pm
The fan belt is a bit loose,now tightened.There doesn't seem to be a loose power feed,but the EDIS plug is a bit wobbly.Fitted a spare one which is a bit tighter,but will probably finish up swapping the connector.GRRR,only 11 wires then......
26th Jun, 2013 at 09:20:04pm
Seems OK now,and I think your loose belt idea may be the problem Brett.Before tightening the belt could hit the sensor holder and being on the slack side of the belt run might vibrate.There were some bits of black material on the sensor holder.
