| Home > Help Needed / General Tech Chat > little help needed.. | |||||||
![]() 16 Posts Member #: 10491 Member north wales |
24th Jun, 2013 at 07:32:21pm
ive been trying to get the clutch and flywheel off now for about 3 weeks and the puller has finaly decided to die..
i fucking hate bi polar!
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
24th Jun, 2013 at 07:42:53pm
We may need pics but sounds like you have unbolted the backplate assembly from the flywheel which has fallen off behind? but you possibly will find the actual flywheel is still on. The only captive bit is the bolt in the centre of the crank and the slotted washer, once thats out the thing holding the whole assembly on is the taper fit onto the crank whick you will need a decent puller to get off, and they can be a right bastard. Stick mini builder dvd on ebay for best results! On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
24th Jun, 2013 at 07:56:14pm
its going on tonight!
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
24th Jun, 2013 at 08:01:32pm
if your not keping the flywheel hit it through the starter hole. i use a 3/8 socket extension bar and big hammer normally just fall off after a couple of hits Done now needs redoing lol |
432 Posts Member #: 2726 Senior Member wakefield |
24th Jun, 2013 at 08:04:40pm
Mine took ages to get off, tie some rope round it so it doesn't fly off. I had a big pole attached, the engine strapped down, my dad and me on the end of it with a bit of persuasion eith a mallet.
24th Jun, 2013 at 08:12:41pm
Best bet I would say is a heavy duty puller but not hydraulic so you can strike the end of the crank, you only have to look at the one Bill has on the dvd-that is really extreme but racers/high rpm/lots vibration are more prone to fretting the flywheel onto the crank almost cold welding it in place. Get the puller on,needs to have an adaptor to fit the centre of the crank too to prevent damage, nice and tight and then strike the centre bolt of the puller towards the engine with a hard mallet/soft hammer-sounds daft but generally works and restrain the flywheel as stated they come off with a right bang and can jump a fair way. A little heat around the centre boss helps too. Edited by oli79 on 24th Jun, 2013. On 18th Oct, 2013 apbellamy said:
24th Jun, 2013 at 08:51:32pm
On 24th Jun, 2013 wng691s clubby said:
if your not keping the flywheel hit it through the starter hole. i use a 3/8 socket extension bar and big hammer normally just fall off after a couple of hits This method can bend the crank as has been mentioned in other posts on this subject. On 7th Oct, 2010 5haneJ said:
24th Jun, 2013 at 09:03:11pm
Ye I've tried hammering the end and the fly wheel
24th Jun, 2013 at 09:39:58pm
Put tension on the pulley then gently heat the centre of the flywheel, if that doesn't work, whilst hot, hit the centre bolt of the puller, that should hopefully shock it off. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Jun, 2013 at 09:55:46pm
I don't mean to sound patronising, but have you taken out the keyway washer?
24th Jun, 2013 at 11:03:33pm
i have had a flywheel clear a good few feet when it finally popped off, it also took most off the crank taper, being a heavy handed fooker i have never really struggled with these
Yes i moved to the darkside |
