| Home > Help Needed / General Tech Chat > fuel starvation (intermittent) | |||||||
25th Jun, 2013 at 12:19:04pm
i have had my car on the road with the current engine for a little while and am still having some niggling problems.
25th Jun, 2013 at 12:24:41pm
not sure how different the pick up is on an mpi tank but on my regular tank it was the shitty little bit of gauze on the end of it that was full of crap and causing me issues before. On 20th Oct, 2015 Tom Fenton said:
25th Jun, 2013 at 09:15:46pm
As Nick says, also possible FPR intermittent fault have a look at that Edited by BENROSS on 25th Jun, 2013.
17th Jul, 2013 at 04:25:18pm
cheers for the input - I have been working through some of the smaller issues I have with the car over the last few weeks.
17th Jul, 2013 at 04:26:27pm
also to add it doesn't feel as lean as it did a few weeks ago, or it does not cut out now. just leans out to 14 ish on load/boost
17th Jul, 2013 at 05:02:11pm
do you still have the bi-metalic jet holder in the fuel float bowl?
Yes i moved to the darkside |
17th Jul, 2013 at 08:29:50pm
so I went for a spin this evening to take a look at things now the roads are quiet and its not as warm. got 2 roads away and it cut out completely. wound bump as it was rolling. had a little look and the crank sensor had unplugged itself! probably on the crater sized pot holes around here. anyway, plugged it in, it runs fine now, afr where it should be etc. was wondering if a poor connection there was the fault. it would be nice if it is! thinking that a weak signal giving a weak spark, not igniting the fuel causing it to run weak intermittently.
