| Home > Help Needed / General Tech Chat > Engine building | |||||||
![]() 102 Posts Member #: 180 Advanced Member Northants |
5th Jul, 2005 at 11:26:42pm
Should finaly start working on my block next week. I'm starting with a early 1275gt block in stage two form. Lightened, balanced and nitrocarbonised crank, rebored to 1293,lightened and balanced conrods, lightend and balanced flywheel. Edited by cheekym0nkey on 5th Jul, 2005. |
6th Jul, 2005 at 04:31:18pm
On 05/07/2005 23:26:42 cheekym0nkey said:
Should finaly start working on my block next week. I'm starting with a early 1275gt block in stage two form. Lightened, balanced and nitrocarbonised crank, rebored to 1293,lightened and balanced conrods, lightend and balanced flywheel. So basicly most of the works been done what i wanted to know is will i gain anything from polishing the inside of the block? #### Nothing - apart from wrist cramp using the die-grinder... ####
What does polishing the rods acheive? #### Removing potential stress-raisers that could lead to a failure. You don't need to go overboard - in fact do you even need to bother in an engine that rarely sees 6500+rpm? #### And Is it better to lower the comprssion by changing the piston or enlargeing the chambers? I would prefer to lower the comp by fitting big cc pistons as i'm undecided on the cylinder head to go for. ### You answered your own question then#### As the one i have is unsuitable i'm considering the 7port head thats in devolpment at minisprt. Could i use a set of bike carbs to turbo though? as there nice and compact. #### If going to the expense of a se7en-port, running anyything other than full injection is - to put it simply - a waste of money in even buying the se7en porter... #### And one last question is it worth getting steel caps for the centre and end ? ####It's worth it if you feel that you will have a problem from the standard caps and that you have sufficient funds. You alone have to decide on the merits...#### On 17th Nov, 2014 Tom Fenton said:
6th Jul, 2005 at 07:49:05pm
Cheers for the reply. Orderd my cooling jets today so should have them next week. Still undiceded on what cam to use! Has anyone used a sw10? |
