| Home > Beginners Tech > 88 Metro turbo project | |||||||
296 Posts Member #: 7876 Senior Member Walsall West Midlands WS1 2DW |
28th Jun, 2013 at 06:07:22pm
Just bought an 88mg metro turbo with a very good body shell. It looks a great bodyshell but its a poor runner.
Patina=old and knackered and won't clean up |
![]() 328 Posts Member #: 9107 Senior Member Devon |
28th Jun, 2013 at 06:34:29pm
In all fairness if you want a reliable engine , strip and rebuild it. Most metro turbo engines have been ragged and its not worth taking the risk .
28th Jun, 2013 at 06:53:13pm
I would rebuild it but I have limited time in the garage and with a mk1 mini to look after garage space and time is limited. The one engine is supposed to have been rebuilt but we will see LOL! Patina=old and knackered and won't clean up |
28th Jun, 2013 at 07:13:36pm
55psi sounds low, was that at wide open throttle? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
28th Jun, 2013 at 07:47:47pm
New to this so maybe going wrong somewhere so bear with me LOL! Disconected coil, Removed plug, screwed in tester turned engine over for about 3 seconds? Does it make a difference if the throttles wide open? Patina=old and knackered and won't clean up |
28th Jun, 2013 at 08:55:09pm
You've tested it correctly, but doing it at WOT allows the air to enter the cylinders quicker so you don't have to crank it as long.
28th Jun, 2013 at 10:29:57pm
Cheers Matty, i'll try again tommorow Patina=old and knackered and won't clean up |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
30th Jun, 2013 at 09:32:27am
55lbs is way to low in my option and blue smoke as well. Take it to pieces mate and overhaul it save your self a lot of time and trouble. Alan Main Build
30th Jun, 2013 at 10:49:59pm
Did it again with throttle wide open and got 75 iish after around 20 seconds of cranking over. Engines out now so I will take a look. Cheers Steve Patina=old and knackered and won't clean up |
