| Home > Help Needed / General Tech Chat > Fuel filters | |||||||
![]() 489 Posts Member #: 9159 Senior Member Devon |
29th Jun, 2013 at 03:39:11pm
Just looking at which fuel filters to use on my turbo set-up, the feed is 8mm and return 10mm and I'm using a carb.
29th Jun, 2013 at 07:44:54pm
I have one filter fitted between the pressure regulator and the carburettor. I would advise against fitting a filter between the tank and pump as that's what it sounds like you ate considering. Own the day
90 Posts Member #: 10229 Advanced Member Stroud |
1st Jul, 2013 at 06:06:46pm
I would ALWAYS fit a filter between tank and pump!! Any small particals could damage the pump. Plus most fuel pumps will come with a warranty disclaimer in them saying a pre filter must be used. If you are at all worried fit one pre pump and post pump. Most good quality filters wouldnt decrease your flow by a noticeable amount (unless your running like 400hp?!) although i wouldnt purchase that horrible thing from jjc. Which is demon tweeks if you didnt know. |
1st Jul, 2013 at 07:47:05pm
^^ Always between tank and pump, i killed a pump in miles because it sucked up shit,
Yes i moved to the darkside |
