| Home > Help Needed / General Tech Chat > KAD Internal Linkage | |||||||
313 Posts Member #: 9367 Senior Member Derby |
30th Jun, 2013 at 06:31:42pm
Is anyone familiar with this setup? I have had it in my car two years now. Ive put the new turbo engine in and now I can't get gears 1 or 3.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
30th Jun, 2013 at 06:34:28pm
. Edited by wng691s clubby on 30th Jun, 2013. Done now needs redoing lol |
30th Jun, 2013 at 06:35:08pm
when I set mine up I place it 2nd (as this is what KAD tell you to do) and go from there. I have started posting on Instagram also my name on there is turbomk1golf
30th Jun, 2013 at 06:38:48pm
It sounds like theres not enough tension on the selector shaft, so it's not pulling it far enough back to go into gear. try setting it up in second instead. Or setting it up in first and giving the adjuster an extra half turn to shorten the selector rod. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Jun, 2013 at 06:52:27pm
It's like the rod is too long cause when you push it forward it won't go yet the threads are all the way in I'm sure. |
30th Jun, 2013 at 07:10:21pm
Is the engine tilted further forward anymore than it was before? That will have the same effect as lengthening the selector rod. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Jun, 2013 at 07:25:36pm
It's a possibility however with the turbo on I have no room to move it back |
