| Home > Help Needed / General Tech Chat > turbo setup Please advise | |||||||
83 Posts Member #: 9728 Advanced Member West bromwich |
4th Jul, 2013 at 10:40:19pm
is this a good starting point advice needed quickly
55 Posts Member #: 9430 Advanced Member |
4th Jul, 2013 at 11:06:39pm
I can remember when you could buy a complete running Metro Turbo for £250! One thing to bear in mind is that even a good looking complete engine and ancillaries usually will still need a rebuild to give close to factory performance, you are missing the carburettor of course and I guarantee it will crunch in 2nd! |
4th Jul, 2013 at 11:33:36pm
the item has ended.
Edited by BENROSS on 4th Jul, 2013.
5th Jul, 2013 at 06:21:19am
I know item as ended but I have been offered it but unsure why tubo is side mounted and could it be mounted on rear of engine as I want to keep brake sefvo |
5th Jul, 2013 at 06:23:55am
as it comes with petrol tank oil cooler and all bits I thought it quite cheep as I can have it delivered at less than what the auction start price was |
5th Jul, 2013 at 06:26:21am
The carb is on it and plenom and petrol reg |
5th Jul, 2013 at 07:04:02am
The manifold is a home brew and looks like a modified LCB. These tend to crack as the tube gauge is too thin.
5th Jul, 2013 at 07:10:42am
but would I be able to buy a rear mount manifold for this turbo and mount on rear of engine |
5th Jul, 2013 at 07:13:32am
Yes. Turbo looks like standard Metro T3, so a standard metro manifold will do the trick.
5th Jul, 2013 at 07:15:01am
I am going to strip the lot and rebuild anyway have done a couple of complete builds on a series engines and box but am new to the turbo side
5th Jul, 2013 at 07:21:14am
is it this one http://www.ebay.co.uk/itm/mg-metro-turbo-e...=item232cc1d692 |
5th Jul, 2013 at 07:26:15am
That's the one. £60 is a bit steep. Especially as the first time you start it the smoke from that paint will restrict your breathing!!!! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Jul, 2013 at 07:27:28am
how much you reckon I should pay then and will I need to get one for carb as well |
5th Jul, 2013 at 08:17:41am
Bet you I've got one in my stash. If something is worth doing, it's worth doing half of. |
5th Jul, 2013 at 08:28:00am
The carb manifold shown is the corrrect one.
5th Jul, 2013 at 09:11:01am
I'll be popping down to my container next week for a look for some other bits. Just drop me a PM if you are interested in an exhaust manifold. If something is worth doing, it's worth doing half of. |
5th Jul, 2013 at 05:33:40pm
just pmd john
1170 Posts Member #: 8636 Post Whore Surrey |
5th Jul, 2013 at 05:56:16pm
If you've already done the bulkhead mods I'd go for a standard metro turbo manifold
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
5th Jul, 2013 at 06:21:25pm
No I got no engine or parts at all yet wrlondon |
5th Jul, 2013 at 10:14:38pm
Not all turbo heads are stamped.
In the 13's at last!.. Just |
6th Jul, 2013 at 06:06:52pm
The pistons are stamped
6th Jul, 2013 at 06:21:08pm
This is it |
6th Jul, 2013 at 07:11:39pm
oops pictures not uploading for some reason |
