Home > General Chat > variable value timing
Mr Joshua
Member #: 1954
Luton Bedfordshire
Question. On variable valve engines what is the maximum angle of adjustment on the cam shafts? and is it an advanced opening adjustment as I belive or do they retard and advance the cam timing around what would be considered normal timing?
Own the day
well thats a comlicated question as most of the systems work differently,
for example the vtec has a different (longer duration) cam lobe and hydraulic follower that is bled down in normal operation, when Vtec kicks in yo the follower is activated so that lobe takes over, I think BMW's Vanos is similar.
the VVC system is (IIRC) the only truly variable duration system and actually slows down and speeds up the cam each engine cycle to achive this,
the latest Vtec and fiats twin air system bleed down the hydraulic tappets during the cycle to get the desired profile.
I think Ive got that all correct :/
Edited by Joe C on 6th Jul, 2013.
bahahaha
Nissans nvcs runs the cam directly and can then advance the cam from its set point when active
its either on or off, duration and lift remain the same
As said, depends on the car and system.
Some are just one position or another, and others are totally variable. And some might be a small amount, others large. I know on Subarus, you can swing about 35deg on later systems.
As for normal....there isnt really any normal with a variable system. Or do you mean what position might it revert to under a fault condition or if the system was turned off ?
Mr Joshua
Member #: 1954
Luton Bedfordshire
I was thinking of start position and failed position. I imagine the position for both would be the same.
Own the day
Johnny
Member #: 6926
Accrington
sod all that cam shit, someone start making a cylinder head for these babys
http://www.youtube.com/watch?v=Bch5B23_pu0
Chalkie
Member #: 9764
Northamptonshire.
VVC system is a pain in the ass when timing up but you've put it in simple terms
http://www.mgfcar.de/VVC_mechanic/vvc.pdf
Like i said a pain but if anyone wished to read up on it.
I guess that assumes that the failure allows return to a specific position, or just lets it run wild.
I did come across a Nissan 200 engine once, and it just let the cam go where it wanted within the mechanical stops of the adjusting mechanism.
WRLondon
Member #: 8636
Surrey
VVC
very very complicated *wink*
that was an amazing vid :o
Edited by WRLondon on 9th Jul, 2013.
Reading up on RTS Clutches
oli79
Member #: 8480
wow
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Mr Joshua
Member #: 1954
Luton Bedfordshire
So this was engine was in test at AVL, my brother is one of their test bed analyst's if that engine was there he may have been involved, time for a call
Funny thing is AVL shut down is European base and shifted back to the states back in 2005-2006
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Valentino Rossi's M1 Yamaha used pneumatic valves to great effect, however the big issue was high fuel consumption.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Spoke to the brother and rumours of AVLs demise in Europe are no longer true. In summary for motor sport any gain is worth the cost but for mass production the gains do not justify the cost.
There was more but you can figure out the rest.
Own the day
evolotion
Member #: 83
Glasgow, Scotland
bmw have two systems, vanos, which alters cam timing, and valvetronic which alters valve lift by adjusting odd shaped rocker arms. the valvetronic equipped engines dont even need a throttle body as the valve lift is so controllable. most manufacturers now do the cam timing thing, mitsubishi and toyota have a variation of hondas vtec setup with a high lift lobe, im not sure anyone has came up with a setup to vary cam duration like rovers VVC, probably due to it being pretty weak/not worth the hastle.
Denis O'Brien.
