| Home > Help Needed / General Tech Chat > Clutch/gearbox issues. | |||||||
6th Jul, 2013 at 10:52:47pm
Right, bog standard 998, whilst driving it goes into gear sometimes really smoothly and other times it doesn't want to go in at all. When you roll the car in neutral it rolls fine, if you put it in 1st with the clutch down it doesn't roll. If you push the car in this condition something is clicking inside the transfer case/clutch.
7th Jul, 2013 at 08:51:07am
Clutch hydraulics issue, fluid leaking from master or slave cylinder or just needs fresh fluid? -MINI CLUBMAN 1380 TURBO- |
7th Jul, 2013 at 09:13:15am
To rule out the wet stuff measure the movement at the top of the clutch arm fully pressed down it should be 1/2 and inch. I run a supercharger and I don't care the TB is on the wrong side.
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
7th Jul, 2013 at 10:31:26am
We don't have any leaking fluid :( They don't die, they just get faster! |
7th Jul, 2013 at 10:40:44am
No leaking issues, plenty of movement at the top of the arm, I've bled the system until I'm blue in the face to no avail. I'm halfway through pulling the clutch, i feel it's something to do with the transfer case for some reason :/ On 26th Jan, 2012 Tom Fenton said:
7th Jul, 2013 at 11:09:55am
And is it the correct hydraulic system for the clutch ?
7th Jul, 2013 at 11:49:51am
Yep, the right slave, throwout set, etc etc etc. Just pulled the clutch and everything was on properly and in the correct order and the right way around. So that's the clutch ruled out completely unfortunately. Could it be an issue within the transfer case? Next thing is dump the oil and pull that off. Failing that it's the box, which I'll be mega pissed off with, as it was only taxed and motd yesterday,and it's already off the road :/ On 26th Jan, 2012 Tom Fenton said:
7th Jul, 2013 at 06:52:18pm
The symptoms you describe just sound like a clutch binding. Cant see how anything in the transfer case could be the problem. 9.85 @ 145mph
7th Jul, 2013 at 07:56:48pm
Yeah, I don't want it to be the box but I can't find anything at all wrong with any hydraulics or the clutch assembly. Do you think it's worth throwing the clutch back on and changing the slave for a new one anyway? Even though I'm getting plenty of clutch travel and no leaks fluid wise? On 26th Jan, 2012 Tom Fenton said:
12 Posts Member #: 10502 Member |
10th Jul, 2013 at 11:42:42am
What about putting the cover and mount back with a few bolts, but without the flywheel / clutch, try pushing it in gear then, see if the noise goes. |
10th Jul, 2013 at 01:15:35pm
Right, been taking off the old hydraulics, replaced the master for the new one that came off my car, and a brand new slave just out the packet. Few things I noticed replacing them, the old slave had only one nut holding it down so it must have flexed upwards, also the pin that goes through the pedal was hanging out, so there must have been play there too. So I've put an R clip through that now after replacing the pin in the new master. Gotta replace the clutch/flywheel and then bleed up the system and I'll report back! Hopefully I don't have to change the box :/ On 26th Jan, 2012 Tom Fenton said:
10th Jul, 2013 at 02:21:02pm
Replace the clutch/flywheel?! Why haven't I been informed about this? They don't die, they just get faster! |
10th Jul, 2013 at 02:26:05pm
On 10th Jul, 2013 ShaunaFTW said:
Replace the clutch/flywheel?! Why haven't I been informed about this? TM is no place for domestics
10th Jul, 2013 at 02:33:15pm
Not replace as in re buy, replace as in put it back! On 26th Jan, 2012 Tom Fenton said:
10th Jul, 2013 at 03:54:28pm
We don't have domestics! This car has brought us close though On 10th Jul, 2013 apbellamy said:
Replace the clutch/flywheel?! Why haven't I been informed about this? TM is no place for domestics ![]() They don't die, they just get faster! |
10th Jul, 2013 at 03:57:31pm
Shouldn't it be reassemble? On 10th Jul, 2013 Carlzilla said:
Not replace as in re buy, replace as in put it back! They don't die, they just get faster! |
10th Jul, 2013 at 08:28:06pm
10th Jul, 2013 at 08:30:33pm
Oh no. I run a supercharger and I don't care the TB is on the wrong side.
10th Jul, 2013 at 08:54:52pm
S'alright! I think we both accepted changing the box at the weekend although my brain refuses to accept it, I'm still convinced it's the clutch haha. He did truely break it tonight though. Poor mini, probably breaks a record the fastest car to be off the road after and MOT! Edited by Shauna on 10th Jul, 2013. They don't die, they just get faster! |
1170 Posts Member #: 8636 Post Whore Surrey |
10th Jul, 2013 at 09:14:04pm
i think its the clutch slave cylinder & pin adjustment as i had the same thing with my pre verto set-up
Edited by WRLondon on 11th Jul, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
10th Jul, 2013 at 09:43:43pm
Well it reluctantly went in a few gears, drove it down the road to take insurance valuation photos, and back a couple times. Then adjusted the ignition timing, put it in reverse, and it wouldn't come out, nor with the engine off or anything. Started it up again and lifted the clutch up slightly and had to yank it out of reverse. Did this twice and gear selection is getting worse. No crunching or anything so I think the clutch is okay. Not good :/ On 26th Jan, 2012 Tom Fenton said:
11th Jul, 2013 at 05:21:47pm
nah your right does sound like the box :(
11th Jul, 2013 at 05:32:38pm
We are getting one from someone we know for £50 but I'm told it was reconditioned no more than 10k ago and works perfectly so fingers crossed! I think he's spent most of today getting ready to take the engine out and depending on when he's got work depends when it will be changed.
