| Home > Help Needed / General Tech Chat > Going from Pre engaged to interia starter | |||||||
90 Posts Member #: 10229 Advanced Member Stroud |
9th Jul, 2013 at 09:39:21pm
I need to convert my my car to run on interia type starter as the engine I have bought has this type of starter. I have the starter fitted to the engine but I need to know which solenoid to purchase and how to fit it into my originally Pre engaged car. Minispares sell either a 3 or 4 terminal solenoid but I rang them today and the guy wasn't overly helpful. Not his fault really as I probably didn't explain myself very well :/
9th Jul, 2013 at 09:51:39pm
in short without going in to detai ring minispares north and ask for richard explain to him in 30 seconds it will be on its way to you
9th Jul, 2013 at 10:00:37pm
Shall do this tomorrow, thanks! |
9th Jul, 2013 at 10:01:32pm
Just buy either. The main battery terminal and power wires go one side, the starter lead the other, and the large spade goes to a smaller one in the centre and so does the old 12v cranking feed for the coil if it's there. If you have a steel roundnose bolt it to the slam panel brace, or the middle of the subframe itself, so you don't have to reroute loads of wiring. On 26th Jan, 2012 Tom Fenton said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
10th Jul, 2013 at 06:25:59am
have a search there are threads with pics that show you how Done now needs redoing lol |
10th Jul, 2013 at 07:23:10am
Just change the flywheel and leave the starter. The inertia starters are shit anyway. http://www.twin-turbo.co.uk
