| Home > Help Needed / General Tech Chat > Too much boost? | |||||||
145 Posts Member #: 5620 Advanced Member Dunstable, Bedfordshire |
10th Jul, 2013 at 09:41:30pm
Hi Guys,
10th Jul, 2013 at 10:05:28pm
you can try winding actuator pe-load off a turn at a time but be carefull to keep some preload or turbo spool up time will suffer
Yes i moved to the darkside |
10th Jul, 2013 at 10:28:44pm
Cheers for that Brett I thought the actuator was how best to lower boost
11th Jul, 2013 at 08:32:44am
Too much boost ?
11th Jul, 2013 at 08:43:26am
Just leave it. 11-13psi is good. If something is worth doing, it's worth doing half of. |
11th Jul, 2013 at 11:56:43am
yeah I know I thought I would get comments like this :)
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
11th Jul, 2013 at 12:25:33pm
gearbox should be fine some peeps running silly numbers on stanard box diff may be your problem if your getting good bhp, pistons should be ok if your timing and fueling are ok Done now needs redoing lol |
11th Jul, 2013 at 12:38:40pm
Just don't go daft booting it everywhere. If something is worth doing, it's worth doing half of. |
11th Jul, 2013 at 05:48:24pm
whats the spec?
11th Jul, 2013 at 08:27:41pm
Is there an intercooler? You will definitely want one Drives
11th Jul, 2013 at 08:57:09pm
if it has standard helical drops and gearset/ diff ......... i can assure you that if you dont turn the boost down to 10 psi or under it will all end in tears for you.
12th Jul, 2013 at 04:39:31am
Hi guys,
12th Jul, 2013 at 04:55:10am
This is a clip from last night after I turned the boost down
12th Jul, 2013 at 07:53:08am
Howley cow spi pistons!! Keep the boost down or it will end in tears Yes i moved to the darkside |
12th Jul, 2013 at 08:23:05am
12th Jul, 2013 at 08:42:35am
I've seen an SPI piston before they don't look particularly robust.
12th Jul, 2013 at 10:10:12am
I have never tryed but i do have a cut up spi piston.. the oil slots must be an inch or so Yes i moved to the darkside |
12th Jul, 2013 at 10:23:11am
I ran 10 psi through my old engine, using non mg metro na pistons. They held up fine. The main thing is to have it set up properly. Though yours could be ok for a budget low boost motor. Whats the compression ratio? Its not ideal though and there is always a slight element of doubt in your mind. If i were you i would get what you have set up properly and build a nicely specced bottom end up as well ready to drop in. |
12th Jul, 2013 at 05:51:37pm
Yeah the plan is to run this but start another engine build as I am already addicted!!
12th Jul, 2013 at 08:04:27pm
The earlier comment about not booting it everywhere is relevant.
12th Jul, 2013 at 08:46:36pm
Tadge44,
13th Jul, 2013 at 10:29:32am
Every time I see this title I have to smile. Own the day
13th Jul, 2013 at 12:35:07pm
my two cents worth is that its more about the driver than the strength of the components meaning i had my 1098cc na motor making 68 odd hp destroy a fresh std box and diff broke the double roller bearing cages the bits of metal when threw the bearings destroying the cam oil pump crank bearings any thing with an oil feed really as well as chew up the gear set and destroy the inner and outer cv joints
