| Home > Beginners Tech > My Mini don't want to start!!!! | |||||||
20 Posts Member #: 10517 Member |
12th Jul, 2013 at 12:10:25pm
Hello everybody,
524 Posts Member #: 1380 Post Whore Swindon |
12th Jul, 2013 at 12:40:38pm
What's your fuelling set up? Edited by Ollie on 12th Jul, 2013. On 2nd Mar, 2008 joeybaby83 said:
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
12th Jul, 2013 at 12:46:04pm
Take the dashpot off, push the choke arm down, and release it, if you see fuel there that should be okay in theory. It is very possible the ignition timing is miles out?
Edited by Carlzilla on 12th Jul, 2013. On 26th Jan, 2012 Tom Fenton said:
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
13th Jul, 2013 at 10:27:33am
Just had a quick read up on your ignition set-up and will make some assumptions about the build and timing being ok. That said, you may want to look at the coil if it's not new or of poor strength it may not have the ability to produce a spark under compression. Sparking in ambient air is easy, sparking under compression is like trying to spark in soup. Own the day
13th Jul, 2013 at 10:49:56am
Do you have a spark and fuel?
I seriously doubt it! |
15th Jul, 2013 at 03:00:44pm
Hi Carlzilla,
On 12th Jul, 2013 Carlzilla said:
Take the dashpot off, push the choke arm down, and release it, if you see fuel there that should be okay in theory. It is very possible the ignition timing is miles out? Get someone to turn the distributor very slowly one way or the other whilst you turn it over. And of course check where number 1 is inside the dizzy at tdc and the leads are the correct order of 1-3-4-2 starting at 2 o clock position and going round anticlockwise. And that number one is the water pump end of the engine. Sorry if any of this sounds patronizing, just making sure
It's also worth finding out the base carb settings so you know it's somewhere near startable. (normally the jet level with the bridge inside the carb) Also check the engine isn't flooded, whip the plugs out, heat them up with a blowlamp or something to burn anything off and leave the bores to breathe through the plug holes for a while. |
15th Jul, 2013 at 03:05:24pm
hi Mr Joshua,
On 13th Jul, 2013 Mr Joshua said:
Just had a quick read up on your ignition set-up and will make some assumptions about the build and timing being ok. That said, you may want to look at the coil if it's not new or of poor strength it may not have the ability to produce a spark under compression. Sparking in ambient air is easy, sparking under compression is like trying to spark in soup. |
15th Jul, 2013 at 03:12:57pm
Hi Paul Wiginton,
On 13th Jul, 2013 paul wiginton said:
Do you have a spark and fuel? Is your 123 the type that you need to load a curve into before you start? |
15th Jul, 2013 at 03:40:16pm
On 12th Jul, 2013 Ollie said:
What's your fuelling set up? Hi Ollie, this is my fuel pump: http://www.gtturbo-online.fr/421-pompe-a-e...1768308912.html my Fuel Pressure Regulators: http://www.gtturbo-online.fr/preparation-m...1768125878.html With a fuel filter 8 mm Facet and a metro turb carb... |
15th Jul, 2013 at 09:05:17pm
Do you have any easy start? If so get someone to spay a little into your carb while you crank if it fires you have a fuelling problem if it does not you have a possible ignition problem. Own the day
22nd Jul, 2013 at 07:31:03am
Hi everybody,
