| Home > Beginners Tech > Turbo engine how to identify | |||||||
83 Posts Member #: 9728 Advanced Member West bromwich |
13th Jul, 2013 at 06:26:58pm
Just stripped my engine i bought no engine number on it and i am trying to identify weather the block and pistons are genuine turbo.
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
13th Jul, 2013 at 06:43:30pm
My pictures haven't worked of late. Upload them on photo bucket then link them. Worked for me BHP sells engines, but Torque wins races! |
13th Jul, 2013 at 08:11:40pm
Yes i moved to the darkside |
13th Jul, 2013 at 08:47:48pm
thanks for your comment |
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
13th Jul, 2013 at 09:01:35pm
Correct there is no such thing as a turbo block but the original turbo build engines had a "T" stamped on the head upper surface left hand side and on the block around the water pump area. The exhaust valve stems are different diameter's as well. Own the day
14th Jul, 2013 at 05:08:52pm
after further stripping found it had a kc500 cam in it would this of been normal for a 1275 turbo as from reading about cam its more suited for a 998 do I use this cam or change it
14th Jul, 2013 at 05:33:45pm
No that is a kent cams reprofiled to the n/a mg1275 spec, it is a good cam very useable i have had one in my turbo engine and it makes a good amount of torqe low down
14th Jul, 2013 at 06:30:26pm
thanks that's pleasing news at least do I need to upgrade the diff and fit centre strap to crank
14th Jul, 2013 at 09:05:15pm
centre strap is not really needed imo, however hi have one and so do many other because whats £45 for that piece of mind lol
