| Home > Help Needed / General Tech Chat > Setting up and needle selection on a 998 stage 1. *Any help today near DY5?* | |||||||
16th Jul, 2013 at 05:49:15pm
Right, now the gearbox seems to be okay after swapping it (to a known good box) I've got to get the car to drive properly.
Edited by Carlzilla on 17th Jul, 2013. On 26th Jan, 2012 Tom Fenton said:
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
16th Jul, 2013 at 05:57:00pm
If I remember rightly I think I fitted a AAU needle in my stg1 998. I also started from the jet fully wound in then backed off either 1/2 turns as a starting point. Edited by TomBooth on 16th Jul, 2013. |
16th Jul, 2013 at 06:01:18pm
Yeah AAU I had in mine too, but I read somewhere that's stage one 'lean' and AAM is stage one normal and AAA is for use with a mild cam change?
16th Jul, 2013 at 06:08:25pm
i have not long since set up a local lads stage one 998, the needle ended up almost exactly the same as an AAU
Yes i moved to the darkside |
16th Jul, 2013 at 06:09:11pm
mintylamb.co.uk
Edited by Brett on 16th Jul, 2013. Yes i moved to the darkside |
16th Jul, 2013 at 06:26:49pm
If im looking at this correctly, the AAU is leaner all round than the AAM and AAA but the AAC is mega lean?
1170 Posts Member #: 8636 Post Whore Surrey |
16th Jul, 2013 at 06:48:55pm
congrats on the box bud
Edited by WRLondon on 16th Jul, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
16th Jul, 2013 at 07:03:20pm
On 16th Jul, 2013 Carlzilla said:
If im looking at this correctly, the AAU is leaner all round than the AAM and AAA but the AAC is mega lean? I think the AAA might be my best bet. yes you are correct, no idea where my figures for the AAM came from? there way out lol, gone to update my spreadsheets Yes i moved to the darkside |
16th Jul, 2013 at 07:07:10pm
looking at these figures ( of the 998 i did) the curve is almost exactly the same as the AAA ( you notice the curve change @ station 8)
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
16th Jul, 2013 at 07:08:03pm
The last part made me laugh, if he has his way I think it would have been a turbo On 16th Jul, 2013 WRLondon said:
congrats on the box bud AAA and what fuel pump are you using? had a mechanical one that was working but didnt pump enough through on my 998 (5 years back now :o) check out the fuel pressure into the carb **EDIT presumed it was a turbo lol** ![]() They don't die, they just get faster! |
16th Jul, 2013 at 07:53:27pm
Well I'm stumped. Got it to accelerate great at standstill in neutral, then took it out on the road and *hfyudghyvgyu* bogs down and no power, if you lift the throttle up slowly theres a spot where it just lurches forwards into life and dies, and lurches forward. I've been faffing with the mixture both ways but I still can't get it to do what I want. If anybody is local tomorrow I would highly appreciate a second set of senses to help out and diagnose what the hell is going on :( On 26th Jan, 2012 Tom Fenton said:
![]() 293 Posts Member #: 10010 Senior Member Northants |
16th Jul, 2013 at 09:51:26pm
I have the full minispares twin-box RC40 on my 998, originally had a AAU which came with the kit, but found it would bog down slightly at full throttle.
16th Jul, 2013 at 10:07:08pm
Choke makes little to no difference, Dashpot oil ive tried 3 in 1 and 20w50. Revs fine in neutral all the way up now, but still shite under any load. On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2013 at 03:53:05am
Do you have a wideband?
17th Jul, 2013 at 08:50:30am
I don't even have a rubber band, nevermind a wideband :/
42 Posts Member #: 9575 Member Nr a shithole (Wolverhampton) |
17th Jul, 2013 at 10:25:26am
stupid question but have you checked the carb float to make sure it's set right?
17th Jul, 2013 at 10:29:01am
Carb float is right checked that a dozen times and its operation, ive been down to my mates and took his dashpot and piston off and measured how far down his jet sits from the bridge and set this carb the same (similar needles and his has carb been rr tuned) Timing makes no difference, blocked off the breather and vac advance with my fingers makes no difference, the vac advance works, jet isn't blocked. I'm gonna put up a couple vids now, one not on choke and one on choke so you can all see/hear what it does (which is pretty much idle and that's it) On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2013 at 10:36:28am
Engine is up to temp...
17th Jul, 2013 at 10:38:15am
17th Jul, 2013 at 01:56:11pm
Yo vids doe work! They don't die, they just get faster! |
17th Jul, 2013 at 02:08:53pm
Oh well. Ive found after much ballache that the carb is at fault. It's not pulling enough fuel through so I'm going to investigate that now. First off i pulled the filter off and put my hand over the inlet practically covering it and the engine dramatically changed. The fact the choke does nothing suggests a blockage or restriction between the jet and float bowl. Popped my mates known working carb on, and jobs a good un! Not quite suited to this engine but I'm not going to mess, at leasylt i now know the problem! On 26th Jan, 2012 Tom Fenton said:
