| Home > Help Needed / General Tech Chat > foamy oil??? | |||||||
![]() 323 Posts Member #: 41 Senior Member |
30th Dec, 2003 at 12:20:31pm
checked the oil level after running the engine, and its all, foamy!?!? loads of air bubbles in it, all falls of the dip stick, anyone seen this before? you cant see if very well from the picture, and the picture doesnt look as bas as it is... A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
30th Dec, 2003 at 02:07:17pm
yes its hot and airated :)
AlexF |
30th Dec, 2003 at 03:49:33pm
ahh, good good! never see oil like that before so got a bit worried A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
14th Jan, 2004 at 12:05:23pm
sure there is no water in there ????? |
14th Jan, 2004 at 12:06:30pm
I am from the pic!!
AlexF |
