Home > Technical Chat > Re trim dashboard
Bigchrismac10
Member #: 10501
Swadlincote
Ok so I'm about to pull my engine out to change the inlet manifold and have a general spruce up under the bonnet. I intend on fitting some new gauges to keep a check on things, I currently only have oil pressure and water temp. I was thinking of adding an AFM, a fuel pressure gauge, boost gauge and volt meter. I was thinking of mounting them in two stacks of three. The problem I have is the dashboard is wood which I don't really like but I have a full roll cage which will make it almost impossible to remove. I was thinking of trimming it in leather look cloth with spray adhesive with the dash in place or possibly spraying it. Any ideas?
dazer_1985
Member #: 9094
near hull
What id do is cut each side just inside the cage take the lot out retrim it all in what you want and fix the parts behind the cage permanent then do what you wabt with the large center part
Johnny
Member #: 6926
Accrington
Don't use contact adhesive. The stuff I used melted in the heat and all the trim fell off. If its wood. Staple it on?
madonminis
Member #: 9371
East Yorkshire
Evo stick contact adhesive. The bruce lee of glues.
APS
Member #: 10369
Pickering, North Yorkshire
How about having it flocked?
www.apsbikes.co.uk
Mat
Member #: 9939
Sussex England
My brother did black suede, looked lovely.
On 17th May, 2013 Rick.SPI said:
Big money if your prepared to do it outdoors in the field.
