| Home > Help Needed / General Tech Chat > Doing away with the Split Diagonal brake setup! | |||||||
8 Posts Member #: 9032 Junior Member |
21st Jul, 2013 at 10:25:39am
Quick Q for the techies....
1170 Posts Member #: 8636 Post Whore Surrey |
21st Jul, 2013 at 11:51:14am
may be a good time to upgrade to discs fella!
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
319 Posts Member #: 1742 Senior Member essex |
21st Jul, 2013 at 04:21:48pm
on the diagonal brake cars i had run larger diameter rear wheel cylinders and when i converted to split front-back i used that opportunity to fit fresh My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
![]() 178 Posts Member #: 10196 Advanced Member |
21st Jul, 2013 at 04:48:19pm
i'm not a fan of the bulkhead mounted compensator i'd run the early type rear subframe mounted ones |
21st Jul, 2013 at 06:39:28pm
Ditch the FAM valve. Fit SMALL rear cylinders if running discs up front. On 13th Jul, 2012 Ben H said:
