| Home > General Chat > Radio aerials | |||||||
27th Jul, 2013 at 08:09:30am
I know fitting a jukebox doesn't come easy to most on TM however it would make sense to have something to listen to while waiting for the AA!
27th Jul, 2013 at 08:10:35am
I have one on the bottom of my windscreen, under the wiper. Seems to work well in the garage, but is starting to peel off. On 11th Feb, 2015 robert said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
27th Jul, 2013 at 10:07:59am
i have an internal aerial which is a think black bar about 6in long stuck it under dash rail got mine from the bay for a couple of quid Done now needs redoing lol |
27th Jul, 2013 at 11:19:38am
I plugged mine into the heated rear screen, you cant use the heater anymore though hahaha
Edited by Brett on 27th Jul, 2013. Yes i moved to the darkside |
319 Posts Member #: 1742 Senior Member essex |
27th Jul, 2013 at 11:33:02am
Just use a normal aerial extended under the dash. Ideally top dash cover if you have one fitted. Or i have used the screen fitted ones before My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
288 Posts Member #: 6267 Senior Member Bristol |
27th Jul, 2013 at 04:26:44pm
Slightly OT, but my Audi 80 had a electric telescopic aerial which I hated. I'd noticed that the top 3 elements on the heated screen did nothing and found they were in fact an aerial. All the wiring was already in place, it was just missing the unit which allows it to use all of the heating elements when it is not being used. I got the missing piece from the breakers, but surely the cost of fitting the telescopic aerial would be more than that part? It appears to have been one of those options which would actually cost the manufacturer less to fit!
27th Jul, 2013 at 04:38:45pm
On 27th Jul, 2013 Flame Red said:
anyway and I'm quite satisfied just listening to 8-Tracks really. you must be even older than me....
27th Jul, 2013 at 05:17:58pm
I'm 27! If I was old enough to remember 8-Tracks I probably wouldn't like them as I'd just remember them for being flawed, expensive and quickly outdated. As it is I love how quirky and retro they are. I also listen to a lot of classic and prog rock, all of which is available on 8-Track. It's impossible to get modern R&B on 8-Track which is a very good thing.
anyway and I'm quite satisfied just listening to 8-Tracks really. you must be even older than me.... ![]() |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
27th Jul, 2013 at 06:39:56pm
A mate in our mini club as put his aerial across and at back of the roof lining, the part that is at the back of sun visors. Main Build
27th Jul, 2013 at 09:12:36pm
On 27th Jul, 2013 Brett said:
I plugged mine into the heated rear screen, you cant use the heater anymore though hahaha Edit:] the volvo and skyline both do this although its not a part of the heater element that they plug in too |
27th Jul, 2013 at 09:25:26pm
good stuff Yes i moved to the darkside |
27th Jul, 2013 at 09:42:02pm
http://www.ebay.co.uk/itm/130647473780?_trksid=p5197.c0.m619
27th Jul, 2013 at 10:36:42pm
hmmm yeah, with that unit though it looks like you could run a hidden loop of wire ( eg around the parcel shelf) i think reception on that would be ok
28th Jul, 2013 at 09:17:29am
I was thinking the same thing brett |
28th Jul, 2013 at 09:21:40pm
rover 800's had a wee module that allowed the rear heater to double as the arial, was very simple to wire in IIRC so if you can find an 800 in a breakers you could rob it.
Edited by evolotion on 28th Jul, 2013. turbo 16v k-series 11.9@118.9 :)
29th Jul, 2013 at 08:45:59am
when was the last time you saw a rover 800 Denis!?
