Home > General Chat > Went to fit up my front end today and nothing fits properly
Clive1330
Member #: 10230
As title I went to fit everything up today but nothing seems to fit as it should :(
Mr Joshua
Member #: 1954
Luton Bedfordshire
Are those all original front panels?
Own the day
Clive1330
Member #: 10230
It's a carbon Kevlar front
eden7842
Member #: 8852
leicestershire
Theres your problem. Did u not mock fit it all?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Have to agree i have not seen many composite front ends that have nice panel lines and gaps.
Own the day
Clive1330
Member #: 10230
I had the shell restored and the front done buy a specialist so I never fitted any off it just the grille lights etc
Mr Joshua
Member #: 1954
Luton Bedfordshire
is the bonnet Kevlar as well?
Own the day
welshdan
Member #: 1111
s wales
to be fair fitting heritage panels to a straight shell still requires a fair bit of persuasion to get them to fit right. so aftermarket/ fibreglass type front ends I would imagine would be worse. anything can be made to fit. with time and more importantly patience. though a mock up pre paint probably would have been the best way to go
Clive1330
Member #: 10230
Yes the whole front is kevlar
Clive1330
Member #: 10230
It was all done at a body shop not by me before they painted it
If they didnt have the lights ect they wouldnt have known it had gaps. Most fg, cf ect has poor fitmant but all can be made to fit better *smiley*
Clive1330
Member #: 10230
Will try again another day just hope I don't damage the paint in the process
dev 11
Member #: 9393
stoke on trent
did they not think to paint the whole bonnet?
Clive1330
Member #: 10230
Bonnet was painted but had to go back to arc angels to be reinforced as the front of the bonnet had the lip cut off it to look mk1 style. They delivered the wrong bonnet. In doing so the scratch the bonnet and ruined the paint
What happened to the slam pannel?
Clive1330
Member #: 10230
Paul it is sat back about 1.3/4 inches from the front of the bonnet if that's what your referring to.
Clive1330
Member #: 10230
Or the scratch was me today losing my temper with it
Fiberglass/carbon panels are for go not show !!
Maybe with a bit of tweeking it might fit better but don't hold your breath.
As dan has said steel panels cant be a swine at times but atleast you can bend and bash those, you carnt carbon
rick
mini.cooper998
Member #: 3772
Wigan
Always build the car up before painting that way nothing is missed. Saves lots of heartache. Sorry to be the bearer of bad news but I had the same issue 9and ended up getting rid of the fibre bonnet and getting steel so I could cut and weld it to shape. The o ly way I could get a good fit with a fibre front.
dev 11
Member #: 9393
stoke on trent
my bonnet didnt fit at all, have a pic around somewhere, i had to raise it at the back on the bonnet pins and it over lapped the scuttle pannel a good 2cm, i was fucked if i was cutting that off
Clive1330
Member #: 10230
Thanks for the replies I knew I should have just done a steel front. Wouldn't mind so much if I had fitted it but paid a small fortune to get it done
welshdan
Member #: 1111
s wales
with any job on the car if you start to get pissed off or frustrated wth it walk away and do something else for an hour. otherwise things will get broken!
maybe the bonnet fitted prior to having the return lip added at a later date?
But like others have said, GRP or CRP panels are far from a great fit. The bumper gaps look about right though even on a steel front
This is the reason I opted to weld on my front end as opposed to having a removable steel front; it is hard getting all the gaps right at the best of times.
