Home > Help Needed / General Tech Chat > Starting Problem When Warm?
turbo55
Member #: 10483
Mini 1380 turbo,
starts fine when cold, and when warm if you start it back up within a few minutes, but if you leave the car for approximatly 20mins, it takes about 30 secs of cranking to start, very reluctant.
when i checked the plugs they were the correct colour,
I was thinking I might need a cooler plug.......
Anyone had this before ?
Specs
Metro T Dizzy
metro T Carb
Many Thanks
Mr Joshua
Member #: 1954
Luton Bedfordshire
float chamber heat soak. all your fuel is evaporating mine did exactly the same thing. common problem.
Own the day
welshdan
Member #: 1111
s wales
yes this is a common problem. luckily mine fires up after a few turns of the engine usually
Yo-Han
Member #: 3228
North of the Netherlands
As above; heat soak.
It helps to fit a heat shield (I am told).
Have a look at this thread:
Dazed and Confused....
oli79
Member #: 8480
With carbs they all do that, hold your foot on full throttle while cranking can help.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
turbo55
Member #: 10483
thanks guys will give it a go
jamestar
Member #: 9159
Devon
I may be wrong, but I remember something about making the jet holder solid instead of bi-metallic? Maybe someone can back me up on this?
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Read the same myself some where on this forum, also read it does not help either. Maybe someone else can shed some light on this subject. I get the same thing happening to my mini. Alan.
Main Build
Upgrade to Turbo
Nick
Member #: 154
Midlands
making the jet holder solid will only really help with keeping a stable mixture.
the hot start thing is just something you have to live with, it's the easy way to spot a turbo'd mini.
nala56
Member #: 9661
Mine only takes a few seconds longer to start just a bit embarrassing when your with a group of mini owners that don't know about turbo minis, but I can live with it. lol.
Main Build
Upgrade to Turbo
