| Home > Show Us Yours! > ERA Evolution | |||||||
40 Posts Member #: 101 Member |
30th Dec, 2003 at 05:37:39pm
Some newer piccies of my mini with the charge cooler on/ in. Some eagle eyed viewers may notice a few wires/ pipes not connected.....dont worry, the photos were taken in mid-fix. |
30th Dec, 2003 at 05:39:42pm
OOPS !!!!
![]() 323 Posts Member #: 41 Senior Member |
31st Dec, 2003 at 12:16:29am
very nice pipe work, looks very neat and tidy. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
31st Dec, 2003 at 01:00:09pm
Thanks
31st Dec, 2003 at 06:13:36pm
i have a similar problem, the front of mine is made into a flip front, and i added brace bars to increase the strength when the front was open, now im finding almost all of it will have to be cut out and different brace bars added A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
1st Jan, 2004 at 12:34:46pm
nightmare!
1st Jan, 2004 at 01:57:56pm
yeah i would like to re-design mine to have a removeable bonnet, maybe a nice carbon one with the weave showing. the conversion is going ok, not much left to do apart from put the seats back in and front windscreen and then run the engine in.
2nd Jan, 2004 at 12:06:20pm
Fortunately or unfortunately, depending on which way you look at it, the charge cooler went on when the weather was turning cold, so the effect was amazing, it was like i was running another 6 lbs of boost!. It will be interesting to see how it drives in the summer months when the ambient temp is much higher. |
