Home > General Chat > carpets
OK, I'm trying to make the car as presentable as possible for MITP. I had originally spoken to Newton Commercial regarding getting a special carpet set made up (the companion bins have been removed in the back so a standard set won't work) but cash is a bit tight with a few other things happening this month (Audi is in getting new brakes all round today!!)
Does anyone know of a budget supplier who might be able to do a special? basically I would need the rear carpet section without the cut-outs for the companion bins and longer inner sill sections
Alternatively a budget supplier who would do a standard set with a roll of matching carpet so I can make the back section up myself.
Longer term, I'll get a better quality set installed so I'm only looking for something that will do a year or so and, given how much time i'll drive the car, about 3 miles road use!
cheers
Rob
Rammie2000
Member #: 10190
belgium
Mini trimings was always a great help to me
Dare I say it, is it really worth putting one in there if it isnt what you want and is just for a short time
I've got a 'high quality' carpet set you can have. It wasn't so high quality, so came back out in favour of an original set. Will be putting it up for sale when I get round to it, but happy for you to borrow it until you get a proper one.
Nic, normally i'd agree but the floor is now covered in cables running to the boot and i'd quite like to hide the state of the patchwork floor!
Andy, will bear it in mind over the next day or so
Evoderby
Member #: 9987
Amsterdam
Your best bet timewise might be to make a cardboard template and drive up to your local upholsterer to have them cut it for you off the roll. Trim the edges with some rubber trim strip and it looks a million pounds.
Alternatively you could use a piece of thin rubber-foam sheet (3 mm?) that you cut to size using your template and spray glue black speaker cloth on top which you fold/glue nicely over the edges. This is basically what they do to make Porsche RS lightweigth carpet sets fit nicely over lumps, bumps and electric wiring.
Good luck!
Good luck!
I like the second idea. Could be a winner
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Removed my question, misunderstood the above.
Edited by nala56 on 6th Aug, 2013.
Main Build
Upgrade to Turbo
