Home > Help Needed / General Tech Chat > Fuel Regulator
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
so im looking for a reg that i can use for a short time while running a carb 3-5psi + boost pressure but id also like to use the same pump and reg for efi + turbo use later with out changing them?
i have found this probably crappy thing what do you think?
http://www.ebay.com.au/itm/NA-TURBO-BYPASS...=item2323887dc5
