Home > Beginners Tech > mather fu...ing ducelier ignition crap shit problem.
Rammie2000
Member #: 10190
belgium
So im working all day long on my sisters mini wich was a bare shell resto.. do e the whole electric beforz painting. . The idiot painter moved some cables around for masking them upp... so done the whole crap again today . Everything works exept the ignition. .. problem is that the car did not have a wire to the coil so placed a new one (still habe to put a resistant wire to it so running on 12 v instead of 9 now... ) but can't get a spark. The car just gives a puff of smoke out the carb when i stopped cranking the engine. So checked the spark plugs. .. nothing! Exept one spark the second i stop cranking. .. over and over again. What do you guys thinck? Its a mk 2 doucelier redtop delco with (thingy that opens and closes as the delco turns) so.. standard oldschool ignition. ..
Strange thing i had it running 2 months ago like this
'you've connected the wire up to somewhere that doesn't get power when cranking.
Rammie2000
Member #: 10190
belgium
Tought so to but failed to look really. .. did choose a other connection on the fusebox(the one who gets power when the lights are on. Most below) but then the engine would no longer turn over. ... will be looking what connection keeps getting power..
wire straight from the battery with a switch in it as a test?
Rammie2000
Member #: 10190
belgium
Yep thats the idea for tomorrow. .. did just found out some more fucks with the wiring to... but now i just want to spend the rest off the day saying yes to tje misses on questions i did not even hear and welding in new tower shock mounting points in my litle rust bucket. .. do you have a idea how much restriction the ballast restricter should have? Can't seem to find it anywhere but would like to weld one in or should i just pop in a 12 v coil?
Rammie2000
Member #: 10190
belgium
The bitch runs. 5 minutes to switch some cable's. ..
Apbellamy i thanks for the idea... sometimes shit is so in front of you that you still don't see it. Do think im going to ditch the points and go electronic
Edited by Rammie2000 on 2nd Aug, 2013.
On 1st Aug, 2013 Rammie2000 said:
sisters
PICS!
sisters
PICS!
Good spot sir!
Rammie2000
Member #: 10190
belgium
sisters
PICS!
Its the older sister. No pic on phone... will take one with her mini.
Johnny
Member #: 6926
Accrington
excellent, dont forget to post it in the sister pics section :)
