| Home > Beginners Tech > id of cam, pistons and crank | |||||||
296 Posts Member #: 7876 Senior Member Walsall West Midlands WS1 2DW |
1st Aug, 2013 at 11:23:32pm
Can anyone help id. these please.
Patina=old and knackered and won't clean up |
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
2nd Aug, 2013 at 01:09:25am
The crank part number is for a1275 "A" plus block MG Metro, Metro turbo and Vandamplah (not sure on the last spelling). Should have bigger main journals I'm not sure if this is the surface hardened item. The pistons are again for the 1275 block at +20 you won't find an oe ring set for these.
Edited by Mr Joshua on 2nd Aug, 2013. Own the day
2nd Aug, 2013 at 06:49:24am
6581 is the very sturdy proper turbo crank.
In the 13's at last!.. Just |
2nd Aug, 2013 at 10:46:13am
cheers guys
![]() 131 Posts Member #: 10521 Advanced Member Aberdeen |
5th Aug, 2013 at 12:16:32pm
Mine has 6232 does that mean mines a shit crank? Flat oot like a dukes fit! |
5th Aug, 2013 at 12:29:09pm
Not at all Baz. 6232 is more than adequate. If something is worth doing, it's worth doing half of. |
5th Aug, 2013 at 12:29:53pm
Thats a standard 1275 a plus crank. Should be fine if in good condition |
5th Aug, 2013 at 03:25:03pm
Good good says the wallet. Flat oot like a dukes fit! |
5th Aug, 2013 at 03:54:23pm
Lots of turbo lumps had the 6232, but the 6581 seems to be hardened in some way.
5th Aug, 2013 at 07:25:45pm
If I am correct there are two cranks for the"A" plus block the two numbers quoted above have the bigger main bearing journals fitted as standard in the models I listed above so be careful when saying it is a standard 1275 crank. This is the reason I build my engines using the blocks from the above models. Edited by Mr Joshua on 5th Aug, 2013. Own the day
5th Aug, 2013 at 07:27:57pm
Got a pic of that cam? Own the day
5th Aug, 2013 at 10:08:08pm
I thought the mains were all identical in size. It was just the big ends which differed.
5th Aug, 2013 at 10:40:11pm
I have a pic of the cam in the engine from underneath but it might be difficult to id it? Send me your email and i'll get the pic to you.
Edited by Steve A on 5th Aug, 2013. Patina=old and knackered and won't clean up |
6th Aug, 2013 at 11:43:40am
Ah yes you could be right there. I remember reading all the component spec on all the various engines and that caught my attention. Sorry if I got that one wrong. Own the day
