Home > Beginners Tech > compresion
neildanks
Member #: 9728
West bromwich
using the formula I found on turbo-mini.com I made a excel spreadsheet is ther anyway I can upload it for others to use on here.
Also the results come up as a decimal number does this mean for example
8.51 would be what you call 8.5.1. or am I missing some thing
neildanks
Member #: 9728
West bromwich
I have just realized 8.5 is the ratio to 1 and result first 2 digits is the ratio
sounds right mate
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i think you need to export it as a img file or something? to then upload is via a host like photo bucket
or perhaps this server will allow a file to be up loaded directly? ive never tried to do it
is this chart consisting of say different heads, pistons, deck heights bla bla if so that body awesome
mossy2a
Member #: 9751
Derbyshire
If you have an I phone there's an app called minihead. It's not a complex calculation but the app saves any confusion.
neildanks
Member #: 9728
West bromwich
Just downloaded app its a bit long winded
wish I could put mine up see what people think
Mr Joshua
Member #: 1954
Luton Bedfordshire
I'm sure there are a couple of calculators on here that you can put your figure's into.
Edited by Mr Joshua on 3rd Aug, 2013.
Own the day
mossy2a
Member #: 9751
Derbyshire
Long winded?? There are 5 inputs. If you want an accurate Compression calculation you must take the smaller things such as gasket and ring gaps into consideration, ideally measuring each cylinder and chamber.
neildanks
Member #: 9728
West bromwich
yes but the way you input your figures on different pull down charts
mossy2a
Member #: 9751
Derbyshire
i simply type the inputs in.
