Home > Beginners Tech > block piston linings
neildanks
Member #: 9728
West bromwich
Does anyone know how much it costs to have this done
expensive! what size is it at the moment ?
and your problem ?
the linerd block can be bored to +0.040"
neildanks
Member #: 9728
West bromwich
problem I have is I bought a set of pistons for std bore but found that engine had been bored +40 I have a spare block but bores will need clean up so I got no cheep options left
mossy2a
Member #: 9751
Derbyshire
i was in a similar position and there is a place in chesterfield derbyshire that will liner the block for i think £30 a bore.
at least you know you will have a mint bore and bang on size.
neildanks
Member #: 9728
West bromwich
so that's £120 have you got a number
for them
mossy2a
Member #: 9751
Derbyshire
i had a few quotes for lining my block from £250 - 400. when these guys said £30 a bore i nearly fainted.
it was foxwood boring.
http://www.foxwooddiesel.com/
i called them up and was in a massive rush, they said if i got it to them in the morning, i could pick it back up the next day. I forget what the std bore size is, but when i asked for that size, the guy was like "thats tiny, no problem when do you want it doing for".
a friend came through on the same day with a different engine so i didnt do it in the end.
that was last september, i cant see it going up much though.
Good luck
Edited by mossy2a on 3rd Aug, 2013.
WRLondon
Member #: 8636
Surrey
Bookmarked
That's cheap!
Would be worth giving them the pistons to make sure it's all good
Edited by WRLondon on 3rd Aug, 2013.
Reading up on RTS Clutches
mossy2a
Member #: 9751
Derbyshire
just found this also
http://www.theminiforum.co.uk/forums/topic...l-machine-shop/
may be of use to you.
Earwax
Member #: 10368
Australia
Hi neildanks - i have seen a number of posts in various sections- you sound like you are on a mission to get this project sorted BUT
it looks like you have already let haste cause delay by buying pistons without knowing bore etc and now you are looking for a solution to that issue. If i may suggest, it could pay you to slow down and put on paper what sort of purpose , idea you have for this beast , and then match it with what you have already got stored away and then of course your budget, time line and own skill level ( how much you can do yourself)
If you post all those things on a build thread - i am sure you will get very knowledgeable folk able to assist you formulating a reliable and good build. - you will get lots of opinions but you will also get the chance to pm some very experienced builders in this regard. Just dont want to see you chasing your tail
mossy2a
Member #: 9751
Derbyshire
The price was my only concern, It seemed a bit too cheap to machine, fit and home the liners. Unless they had some old stock or something.
On 3rd Aug, 2013 WRLondon said:
Bookmarked
That's cheap!
neildanks
Member #: 9728
West bromwich
As far as buying pistons they were acquired after advice that turbo or forged pistons where required, as far as engine builds go I am quite knowledgeable and this is my seventh mini project in 6 years.
I have just completed a full Honda vtec conversion including wiring and subframe build suspension etc . So I am quite wise wise to projects and planning, I have an end goal and a budget set I know what mods I am doing but I am naïve as far as turbos go but I am learning daily and understanding the principles.
As far as haste I am in no major rush to complete my project as I am in need of completion until april next year.
The reason I am asking questions is so I don't go the wrong way, I gather all information i am fedback and decide my best course of action, I am sorry if the way I do this seems wrong but I find it easier to take in the knowledge this way. I am 48 years old and find it more difficult to learn now than what I did when I was younger.
I don't mean to write this sounding un-appreciative but only to explain to people my position.
Edited by neildanks on 4th Aug, 2013.
Have a look at rob walker engineering, he offer sleeving and reboring at good rates.
neildanks
Member #: 9728
West bromwich
His prices seem good don't they apart from the distance looks good.
Rob Walker is good, nice chap too.
neildanks
Member #: 9728
West bromwich
I need to decide what I am going to have done total as I may get a reduced rate on the more I get done lol
I'm getting my crank worked by rob, and I'm also thinking of using a mini spares 4 bolt cast centre main and having it line bored at the same time. With machining 90% of the time is usually spent setting up, the rest machining, so having more than one thing done at a time will usually be cheaper.
He's a nice honest bloke, and his work is spot on.
madonminis
Member #: 9371
East Yorkshire
I had this done last week at classic and modern. Plus cam bearings and block resurfacing and a couple of other bits was around 400
