| Home > Help Needed / General Tech Chat > Effects of boost | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
4th Aug, 2013 at 07:46:26am
I've been thinking about the direct effect of adding boost to a Naturally aspirated engine. For example I had 100hp from my new 1380 7 port engine running without turbo at 100kpa. Therefore now with the turbo fitted at same compression ratio (9.8-1) and 140kpa (6psi boost) I should expect 140bhp?
Edited by alaskanow0 on 4th Aug, 2013. Class C 3rd Place Avon 2011 14.18 @101mph |
4th Aug, 2013 at 09:06:46am
On 4th Aug, 2013 alaskanow0 said:
What confuses me is certain 5 port engines claim to be running 150bhp at 10 psi, with mild road cams. They would need to running 105-115bhp in naturally aspirated form to achieve this. Also seen people claim 200bhp from 14.7 (1 bar), this again equates to 110-120bhp with loses This can't be right, can it? Unless proven claims are all they are! If something is worth doing, it's worth doing half of. |
4th Aug, 2013 at 09:23:47am
That's a good point John.
4th Aug, 2013 at 09:25:30am
I don,t think that you can straight line extrapolate the figures as you have suggested.
4th Aug, 2013 at 09:31:14am
What confuses me is certain 5 port engines claim to be running 150bhp at 10 psi, with mild road cams. They would need to running 105-115bhp in naturally aspirated form to achieve this. Also seen people claim 200bhp from 14.7 (1 bar), this again equates to 110-120bhp with loses This can't be right, can it? i have often wondered the same mine was 22 psi to crack 200bhp, and i think my calculations are more accurate than a dyno Yes i moved to the darkside |
4th Aug, 2013 at 09:31:45am
I totally agree there are so many variables to take into account. Just trying to understand the theory really. Edited by alaskanow0 on 4th Aug, 2013. Class C 3rd Place Avon 2011 14.18 @101mph |
4th Aug, 2013 at 09:34:11am
i dont see why is so important to make X nanas or curllys if you feel its slow turn it up and build it better/stronger
4th Aug, 2013 at 09:43:14am
One thing I'll chuck into this,
4th Aug, 2013 at 09:50:04am
Yep! Mike made great power on little boost with his side mount. If something is worth doing, it's worth doing half of. |
4th Aug, 2013 at 09:55:25am
That's a good point, my 100bhp base line is taken with a lcb fitted. If the log style manifold effectively reduces power under boost then more losses need to be taken into account. Class C 3rd Place Avon 2011 14.18 @101mph |
4th Aug, 2013 at 10:16:59am
Also although one would expect similar. or perhaps lower VE when correctoed for boost on a turbo motor, I suppose there can be situations when a port/ manifold/carb etc is more efficient when being blown down rather than sucked,
4th Aug, 2013 at 11:22:04am
15psi boost at >7000rpm = 200hp+
4th Aug, 2013 at 02:03:56pm
I understood that you could expect 4bhp from each psi you increased the boost by so you would be looking at 124bhp Own the day
4th Aug, 2013 at 04:09:58pm
On 4th Aug, 2013 Mr Joshua said:
I understood that you could expect 4bhp from each psi you increased the boost by so you would be looking at 124bhp Your maths is correct as a basic estimation. But there are lots of factors to consider. The measurement of power and boost for one. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th Aug, 2013 at 05:02:11pm
compression ratio
4th Aug, 2013 at 05:06:12pm
Ok, so considering all things equal, ie same rpm, fueling, air temp, transmission loses etc, the formula looks ok in principle.
4th Aug, 2013 at 05:14:37pm
not as simple a question as you think.
4th Aug, 2013 at 05:28:23pm
as above,
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
4th Aug, 2013 at 05:45:45pm
I think that the first thing you have to consider is that it's not boost that makes power but mass flow. You can have a shitload of boost and not much flow ( think about blowing through a tiny straw vs a big straw, first one will have a much higher boost pressure but a lot lower mass flow). when you put in a more efficient turbo you reduce the bottle necks on both ends of the chain ( they are physically coupled as well so any restriction in the chain will affect both sides ) and it will be able to move a bit more mass into the cylinders . Put on a better head, better intercooler : more mass flow more power.
