| Home > Help Needed / General Tech Chat > Rollcage spreader plates | |||||||
4th Aug, 2013 at 08:16:47pm
So the rules as I understand them are as follows, if you are welding a cage in it should have a spreader plate on the inside of the car. If it is being bolted in, it needs a plate each side.
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
4th Aug, 2013 at 08:40:23pm
My old safety device multi point cage came with internal spreader plates to be welded on Avon 2010 class c 3rd
4th Aug, 2013 at 09:20:49pm
Yes, as far as im aware you weld the plates inside then bolt the cage to them.
4th Aug, 2013 at 09:51:59pm
Cheers chaps
5th Aug, 2013 at 04:20:05am
There is an advantage to fitting the outer plate, which is that it gives you a handy place to jack the car up without damaging anything.
5th Aug, 2013 at 12:30:20pm
Good point Tom
