Home > Help Needed / General Tech Chat > Turbo Van fuel tank
paul25
Member #: 596
Anyone with a turbo van?
Have you modded the original tank outlet? I have added the return line into the filler neck, but am concerned about fuel delivery through the standard outlet as it is only 1/4" OD-should I be?
Any help appreciated!
AllanMcD
Member #: 414
Dalbeattie Scotland
I run the standard outlet but I kept the small bore bit as shot as I could I used a new pump and there is plenty of fuel flow.
Edited by AllanMcD on 12th Jul, 2005.
http://www.rabdunn.co.uk/
Here is a tip for van / pickup turbo guys!
http://www.16vminiclub.com/forums/viewtopic.php?t=3472
