Home > Beginners Tech > Gearbox
Baz_rsp
Member #: 10521
Aberdeen
This might be a stupid question, but as I'm new to the A series I though I'd ask. I have been offered a gearbox from a 998A+, and was wondering if it would fit my 1293 A+ turbo engine? I know the diff will not be man enough but what about the rest of it?
Flat oot like a dukes fit!
It will physically fit, but if you put any power through a used and unknown standard box it will only end in tears and ££££££
Baz_rsp
Member #: 10521
Aberdeen
Ok cool. But the casing will be ok? I have no box at all just now so looking for a starting point.
Yeah, the casing will be fine. You might be lucky and get a more desirable final drive. Always worth having a few donor boxes for synchro hubs, baulk rings etc
Baz_rsp
Member #: 10521
Aberdeen
What seems to be the final drives to go for? 3.2?
Depends on gear ratios and wheel size. Have a look at guess works ratio calculator once you have picked your gear set.
minimauritius
Member #: 10545
MAURITIUS
STRIP IT before you use it.
I just made the mistake of not doing it and a diff bearing ball found is way through the gears !
the plastic cages in the bearings were broken. Now the new bearings seem to be steel caged.
Baz_rsp
Member #: 10521
Aberdeen
Ok thanks. I was going to strip the box to replace the bearings anyway. I would like to put sc gears in but funds don't allow me to do that just now. Is there a set of gears that I should fit just now to get me on the road with out costing 400 odd pound.
Baz_rsp
Member #: 10521
Aberdeen
Thank apbellamy I will have a look
WRLondon
Member #: 8636
Surrey
ill be the smart arse and say that there was one model 998 gearbox which catches the crank
which one & year i cant remember but there was a post on TMF 2/3 years ago on it
the likely hood of it being yours is slim but worth a check
Reading up on RTS Clutches
Use the standard gears, but replace all the bearings etc. Check the gears very carefully for wear. It might take a few boxes to get a good combination of parts to make one usable unit.
Baz_rsp
Member #: 10521
Aberdeen
Thanks for your help. That's a good website never knew they existed.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Also if i remember the bearing in the transfer case for the input gear is smaller than on the A+ 1275 item. Worth a mention
Own the day
Wrong. They are all the same. The turbo bearing is bigger, but 998 & 1275 N/A are the same.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
That's true I have one of those gearboxes, still can't tell you the year because I bought the engine and box from a mate but if there is any markings on the casing that any one knows about I can check it out. Alan
Main Build
Upgrade to Turbo
I think Mr Joshu is referring to the idler gear bearings in the side of the gearbox and transer casing - they are smaller on a pre-A plus (whatever capacity).
nala56
Member #: 9661
I've also herd it can be ground away to make it clear the crank, don't know how successful that is or if its true.
Main Build
Upgrade to Turbo
Mr Joshua
Member #: 1954
Luton Bedfordshire
No matter I miss read thought it was"A"and A+. Getting most things wrong at the moment may be because I'm messing around with a Subaru at the moment *frown*
Own the day
