| Home > Help Needed / General Tech Chat > Metro turbo 1380? | |||||||
28 Posts Member #: 10398 Member Swansea , Wales |
8th Aug, 2013 at 08:02:15pm
Hi in was wounding if it was possible to 1380 a mg metro turbo engine , if so what would I need to change to withstand the added power ? Obviously I would need to bore the block and get new pistons ( 73.5) And also would it be possible to un-turbo the engine , the reason for this is that I just passed my test and I can't effort the turbo but I can effort the 1380 insurance , thanks jake |
8th Aug, 2013 at 08:20:35pm
Remove turbo, bore, add pistons, check compression ratio, skim head if needed, remove carb and fit n/a hif44 and reset fuel pressure to 4psi or just remove it all and fit a normal n/a pump. In a nutshell. But 1380 is nothing alone, you need a decent cam and head. Just going from 1275 to 1380 wont really make all that much difference alone. On 26th Jan, 2012 Tom Fenton said:
8th Aug, 2013 at 10:54:10pm
So there no point me boring my standard metro turbo engine to 1380 , only if I change cam , crank etc.. ,if I went down the road of boring , will I need to change much on the standard engine if I do what do I need , thanks |
1170 Posts Member #: 8636 Post Whore Surrey |
8th Aug, 2013 at 11:03:12pm
Wouldn't bother at your age tbh
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
9th Aug, 2013 at 06:50:46am
Take it to 1293, stick an sw5 in and something like a big valve mg metro head.
![]() 178 Posts Member #: 10196 Advanced Member |
9th Aug, 2013 at 08:13:02am
If your young, you can get plenty of power from an 998 by fitting a decent stage 1 kit, granted bigger engines will get there quicker, but 1 998 can still reach and cruise at 70 and is probably alot more reliable |
