Home > Help Needed / General Tech Chat > which engine fan
era mini mark
Member #: 10523
PALM BAY FLORIDA U S A
Hello, can anyone tell me which engine fan will cool the best. my understanding is the 2 blade fan should be the best n I also heard that you can put two of them together. does this make it more cool ? also I noticed the newer minis have n electric fan as well. is it ok to have a standard fan n then n electric fan ? do they cancel each others out n anyway ? or is that the way to go. plz advise if anyone truly knows the answer n may have experience these situation. thx u
WRLondon
Member #: 8636
Surrey
you can put an electric fan on the inner wing
just make sure you set it up to pull the air out as appose to fight the rad fan
can set it up on a switch you control or when the car reaches a certain temp
i'd get a performance rad before you do that though as it involves modifying your era!
Reading up on RTS Clutches
era mini mark
Member #: 10523
ok, but does any of the fans that's mounted to the water pump flows any more cfm than the other, example 2 blades vs 4 blades etc etc. thx u
