Home > Help Needed / General Tech Chat > dropped a bollock, healboard help needed
mini.cooper998
Member #: 3772
Wigan
HELP ive dropped a bollock, finally got the underside of the car all painted up so though I would assemble the suspension.Got my beam ready to fit and started by running my tap own all 4 healboard screws all fine. Loaded the beam onto the jack and lined it all up. Im being carefull and decided to use stainless bolts. Copper slipped up first three ran in perfect 4th has gonein so far and the stainless has picked up and stuck in the nut. Unfortunately in a stupid move ive over loaded it and the nut has parted company from the heal board. So the whole lot is turning. I can get a slitting disk in to cut the bolt but how do I get it out and how do I weld a new one in. Cheers in advance.
sucks teeth...
tricky one, what I would do is get a large thick washer (about 19mm?) , weld a nut to it, tthen drill the heel board to the diameter of the washer (fish the old nut out) and weld the wash and nut in flush, knock back the welds and repaint that area.
any one got any better ideas?
Pull bolt back and try and tack it on if you can get the welder on? Accidentally did this yesterday lol
mini.cooper998
Member #: 3772
Wigan
Option 2first then option 1, also thought hole saw inner sill and then plate over after.
I once managed to split the spotwelds on the pinchweld on the inner sill, weld in a new nut and re weld the spotwelds .........if that makes sense
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Use a silting wheel as you sudjest, cut the the bolt off drill out the hole to the size of a rivet nut, the blind type as in the picture below. Fit your beam and I would then steadily run a tap through it with the beam fitted, screw in your m8 bolt. Job done. Alan.
Ps. The rivets I have use a 10.5mm hole.
Main Build
Upgrade to Turbo
madonminis
Member #: 9371
East Yorkshire
On 10th Aug, 2013 Joe C said:
sucks teeth...
I've done this on the cross beam to fit my seat subframes. Works a treat for that.
I really wouldnt advise a rivnut
nala56
Member #: 9661
Paul don't under estimate these rivets, they are not soft ally they are really strong more thread inside them than a standard nut, and when all said a done he's got three other bolts in there, in my pinion plenty strong enough for the job.
Main Build
Upgrade to Turbo
mini.cooper998
Member #: 3772
Wigan
I have the use of a good rivnut set and agree they are strong. We use them at work alot. However will be drilling a hole in the inner sill big egnough to get a ring spanner in then nut and bolting it and putting a rubber grommet back in the hole for later undoos
mini.cooper998
Member #: 3772
Wigan
The wife will just have to help
nala56
Member #: 9661
It's a nice idea that mate, you won't see the grommet without looking for it, saves you burning the paint off plus the fact that when you start welding and can't get to paint it oxidisation sets in speeding up the rusting proses. It's a very bad place for rust to start with. Alan
Main Build
Upgrade to Turbo
mini.cooper998
Member #: 3772
Wigan
The grommet will also come in handy for cavity wax, and im sticking to that story with the mot inspector.
nala56
Member #: 9661
Never though about the MOT man, I think any holes or the like have to be 2inch away from a stress point, or does it just mean rust damage. I suppose it depends on the digression of the inspector.
Main Build
Upgrade to Turbo
mini.cooper998
Member #: 3772
Wigan
Carpet to cover it me thinks
nala56
Member #: 9661
I think you'll be fine mate.
Main Build
Upgrade to Turbo
I know rivnuts very well and use them very regularly - Aston Martins are covered in them. Theyre only fit for holding on undertrays and headlights, definately not suspension
Agreed to the above, I would never use a rivnut for suspension componants, in my personal opinion its like using a second hand condom.
mini.cooper998
Member #: 3772
Wigan
managed to drill the plate between the inner cill and body seam egnough to get a tack weld on and then wind it out. cheers all for the advice. beam now in and some suspension fitted.
Thanks again
nala56
Member #: 9661
Ok I get what your saying Paul. And Paul R.
Edited by nala56 on 11th Aug, 2013.
Main Build
Upgrade to Turbo
