Home > Help Needed / General Tech Chat > MPI STalks on a non MPI
mini.cooper998
Member #: 3772
Wigan
as the title says im after fitting MPI stalks to a non injection loom, has anyone tried it and if so what did you do. Also is the mpi stalk the same as the MGF and Rover 100.
dev 11
Member #: 9393
stoke on trent
yeh i did this by creating my own custom loom, worked great only downside is the stalks must be used with the mpi column and wheel bosses are more expensive
dazibee
Member #: 1356
TRURO, CORNWALL
Can be made to fit a non mpi column quite easily
mini.cooper998
Member #: 3772
Wigan
buety, guess its just a case of transposing the wiring from the switch to the column instead
Yes did this years ago, the wiring diagrams from haynes are a good start i had issues with the wipers though so i ended up with 2 slow speeds and a fast
Tupers
Member #: 9441
South Devon
MG stalks are largely the same as MPI ones although they have a added rotary switch on the right hand stalk for rear screen wash/wipe.
I'll be using MG stalks on my estate and will set-up the sprung return on the rotary switch as my horn and leave the other possessions on it dormant.
Tbh i thought they were the same, mine are as you described so maybe mine are mg ones... some civics have them too
mini.cooper998
Member #: 3772
Wigan
in want to bin the switch panel off in the middle and this helps by removing one of them.
mini.cooper998
Member #: 3772
Wigan
Mgf one bought £8 vs mpi starting at 30 jobs a good un
