| Home > Help Needed / General Tech Chat > Talk to me about fuel & air | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
12th Aug, 2013 at 03:25:53pm
right, this is assuming the engine's timings etc. all sorted
Edited by WRLondon on 12th Aug, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
12th Aug, 2013 at 03:27:36pm
im at the stage of thinking i should take the 40psi pump back out and put the 9.5 psi one in
12th Aug, 2013 at 04:13:30pm
you need the pump to be able to over power the boost pressure
On 12th Aug, 2013 WRLondon said:
right, this is assuming the engine's timings etc. all sorted standard 1275 carb'd (high velocity low pressure air) atmosphere + 3.5psi fuel pressure should be enough to get the fuel through turbo 1275 (converts to low velocity high pressure air) atmosphere + 3.5psi fuel pressure at no boost then your compressing air blowing it in the carb to force more air through along with more fuel = poweerrr first bit of advise i always give, take the carb piston and needle out and turn on your fuel pump if fuel squirts out the jet your float valve needle is not set correctly or leaking Yes i moved to the darkside |
12th Aug, 2013 at 04:20:20pm
Im being told by a very experienced mechanic that i should be running the 9.5 pump as 40 is too high and tell him from me if he doesnt know what the fuck he is on about.. keep his trap shut! 40psi is to high at idle but your pump does not produce this...what you think the fpr is for? and why does it increase the fuel pressure with boost if you set the fpr to 3.5 psi at idle the whole fuel system is at 3.5 psi this is the most basic of stuff aswell ![]()
12th Aug, 2013 at 04:21:01pm
sorry my minds abit mashed at the moment haha
12th Aug, 2013 at 04:22:44pm
exactly what i thought
Im being told by a very experienced mechanic that i should be running the 9.5 pump as 40 is too high and tell him from me if he doesnt know what the fuck he is on about.. keep his trap shut! 40psi is to high at idle but your pump does not produce this...what you think the fpr is for? and why does it increase the fuel pressure with boost if you set the fpr to 3.5 psi at idle the whole fuel system is at 3.5 psi this is the most basic of stuff aswell ![]() ![]() Edited by WRLondon on 12th Aug, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
12th Aug, 2013 at 04:25:01pm
so will too much fuel pressure will force the float on the carb open, overflow the resevoir an spray too much fuel into the intake? yes On 12th Aug, 2013 WRLondon said:
or even force the diaphragm open without splitting? stiffer spring needed? the is no diaphragm in the carb its a float no spring as such either (there is but it should be fully compressed or there abouts) On 12th Aug, 2013 WRLondon said: set fuel pressure to 3.5 psi at static or at idle then sort out your carb
i did say i need to set up the fuel pressure but apparenlty that doesnt matter and its the air pressure thats the problem? Yes i moved to the darkside |
12th Aug, 2013 at 04:28:02pm
i meant diaphragm @ the regulator
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
12th Aug, 2013 at 04:29:04pm
I bought one of these
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
12th Aug, 2013 at 04:45:27pm
which fuel pump then?
Edited by WRLondon on 13th Aug, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
12th Aug, 2013 at 04:56:00pm
40psi.
12th Aug, 2013 at 04:59:35pm
the proper metro one
12th Aug, 2013 at 05:03:34pm
first bit of advise i always give, take the carb piston and needle out and turn on your fuel pump if fuel squirts out the jet your float valve needle is not set correctly or leaking Just checked & Fuel pisses out the jet -.- Would this be a fault regardless of whether I've properly setup the fuel pressure yet? I've wound the FPR screw out most of the way and there are no blockages in the return pipe I know I probably come across as an idiot but if I don't ask I'll never know
12th Aug, 2013 at 05:09:35pm
Also the return pipe is plumbed to the top of the petrol tank so not a lot of pressure needed to return Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
12th Aug, 2013 at 05:09:42pm
9.5psi pump is theoretically only good for 6psi boost. I certainly wouldn't trust it at even that little boost.
In the 13's at last!.. Just |
12th Aug, 2013 at 05:16:34pm
have a look at this from about 35 seconds on....
12th Aug, 2013 at 05:23:19pm
Fuel squirts out regardless if I set the FPR screwed out to the max or in
12th Aug, 2013 at 05:39:16pm
Had you rebuilt the carb before you fitted it? if not then i'd get a rebuild kit for it and do that while you wait for a pressure gauge http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
12th Aug, 2013 at 05:45:53pm
ok, sounds like it could be the float valve as you say,
12th Aug, 2013 at 05:54:32pm
Was meant to be a rebuilt carb but Ebays like that
12th Aug, 2013 at 07:01:25pm
what pump do you have and what pump are you being told to use?
12th Aug, 2013 at 07:05:18pm
Fuel squirts out regardless if I set the FPR screwed out to the max or in The diaphragm isn't split and I've got 2 good ones :s So think I need to re-adjust or rebuild the float valve anyway Lol that's the video I watched yesterday And the name suggests it regulates the fuel pressure
Ordered a gauge so we'll see Fuel should NOT flow out of the jet on its own. If it does, I'd be first checking your dipstic for oil level and be thinking strongly about changing your oil before you wipe out the engine bearings! I'd then replace the needle vave in the float chamber and making sure the fuel pressure goes no higher than 5psi with the engine off. don't start the engine untill you have done these three things!!!................. On 26th Oct, 2004 TurboDave16v said:
12th Aug, 2013 at 08:21:37pm
There seems to be a mix up in how the pumps are being rated. Just spoke to my brother to make sure I have this right but I do believe pumps are rated by flow rate. A pump free pumping into an open Vessel creates flow but no pressure it is the restriction of the return path that creates the increase in fuel pressure we see between the fpr and carburettor. The standard pump fitted to the metro turbo is the same item fitted to the SD1 Maestro and Montego efi and is capable of sustaining a fuel rail pressure upward of 8bar, now this is a rough figure comparing it to the Bosh unit fitted to XR3i which I know can go much higher. According to my brother he would expect to see around 100psi or more in the fuel rail possibly lower but but 100 is already low.
Own the day
12th Aug, 2013 at 08:25:21pm
Started writing the above about an hour ago dinner got in the way but two explanations saying the same thing. Own the day
225 Posts Member #: 3772 Senior Member Wigan |
18th Aug, 2013 at 09:47:13pm
Are you usingna genuine turbo carb or an hif44. I had the same issue when using an hif44. Ive also had the same issue when I put the wrong pipe direction into the regulator. All a leqring curve. |
