Home > General Chat > lsd help
eden7842
Member #: 8852
leicestershire
After some advice,
After pod and spinning up 1 wheel more im after an lsd. Atm I have a 2.9 fd and want a 3.1 next.
Can you get them for an lsd?
Cheers eden
If you buy the later design Quaife it will allow you to use your existing final drive or any other standard final drive. Older LSD's require a specific crownwheel and are usually limited to short ratios e.g. 3.7-3.9-4.1 etc.
Yes atb LSD from swiftune would be my choice for you
welshdan
Member #: 1111
s wales
Atb is great. I put 160 bhp through mine. Car has a big turbo so does take a little bit to get the car going but its nearly impossible to even get a squeel from the tyres when you put your foot down. It puts all the power down to the road.
eden7842
Member #: 8852
leicestershire
http://www.swiftune.com/Product/381/atb-di...assic-mini.aspx
Is this the one then? And would I be right in sayin I replace those allen bolts with my c/w bolts?
Your C.W. bolts in the holes outside of the allen bolts.
eden7842
Member #: 8852
leicestershire
Ah cheers andy. They looked far apart.
Thats the one il go for then. Hopefully shave my 1/4 mile a tad more.
jamiestevenbell
Member #: 9941
Derby
Does the quaife atb diff fit within the standard diff housing without modification? And do they actually help with reducing torque steer?
We had to relieve John's diff housing slightly, but nothing major. Went straight in mine.
Star Mag
Member #: 375
Leicestershire
They will highlight poorly setup suspension! Ask me how I know :)
eden7842
Member #: 8852
leicestershire
Something to do with your setup ron?
Star Mag
Member #: 375
Leicestershire
Yeah poorly set up suspension! Now rectified :)
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
what about the headlamp!
16V project underway
