| Home > Help Needed / General Tech Chat > revs funny after long run | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
14th Aug, 2013 at 10:14:26am
Great weekend at MITP, good to see a couple of you guys too.
14th Aug, 2013 at 10:22:37am
Throttle cable sticking?
14th Aug, 2013 at 10:45:18am
Was a a love sunny drive home, throttle cable is free.
On 14th Aug, 2013 Kean said:
Throttle cable sticking? Carb freezing causing throttle to stick? What the mind can conceive the mini can achieve
14th Aug, 2013 at 10:50:54am
Bin it and put a hif44 on On 26th Jan, 2012 Tom Fenton said:
14th Aug, 2013 at 10:52:53am
No chance, sounds great On 14th Aug, 2013 Carlzilla said:
Bin it and put a hif44 on ![]() What the mind can conceive the mini can achieve
14th Aug, 2013 at 10:54:15am
air leak of some sort? my turbo idles higher when hot |
14th Aug, 2013 at 10:58:11am
But yeah, check all the throttle linkage is moving freely when the engine is hot under the bonnet, make sure nothing is catching when hot. Give everything a good dose of wd40 and see if the problem disappears. If not is it maybe fuel leaking past a float bowl seal when warm? (not sure how fuel delivery works on them) On 26th Jan, 2012 Tom Fenton said:
14th Aug, 2013 at 11:22:12am
It doesn't really matter if it was a nice sunny day, at a constant high speed you can still get carb icing which could cause the sticking
14th Aug, 2013 at 11:37:32am
is the manifold a water heated type also connected up? |
14th Aug, 2013 at 03:00:22pm
no water heated manifold, going to order a service kit for the weber but may try a spray around it first with carb cleaner and see if there is any air leaks.
614 Posts Member #: 2153 Post Whore kings langley |
14th Aug, 2013 at 03:37:09pm
Worn throttle/spindle bushes? Or as said air leak? Do u have a nice strong return spring? Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
14th Aug, 2013 at 04:19:02pm
Still has both springs on to close throttle, think I'll shorten them a little and check throttle spindle since I need to take carb off anyway.
On 14th Aug, 2013 supermotolee said:
Worn throttle/spindle bushes? Or as said air leak? Do u have a nice strong return spring? What the mind can conceive the mini can achieve
![]() 84 Posts Member #: 10419 Advanced Member |
15th Aug, 2013 at 06:18:43pm
Odd thing to check but sometimes if your gas heats up it revs high, so check where your fuel line is in corralation to your muffler and the ehaust manifold. It helped me out tons. |
15th Aug, 2013 at 07:51:05pm
could be something daft like hot oil = less resistance, then if the revs slightly higher + more ignition timing on that part of the map will = alot more revs
Yes i moved to the darkside |
15th Aug, 2013 at 09:35:18pm
Carb icing is my bet. Next time it goes it leap out and check the throttle cable, I bet it has gone baggy as ice is holding the butterflies off.
