| Home > Technical Chat > compression testing | |||||||
13th Jul, 2005 at 11:17:46pm
what have you lot got on here when you compression test your engines Crystal Sound Audio said:
13th Jul, 2005 at 11:55:01pm
13 bar on a standard 9.4:1 turbo engine.....when warm i.e. run for a couple of mins
Edited by Dangerous on 13th Jul, 2005.
14th Jul, 2005 at 07:39:46am
i had 120psi +/- 2 psi across all 4 after i'd run my engine in, thats with an 8:1 CR.
14th Jul, 2005 at 07:42:25am
Mine are around the 100psi mark.
14th Jul, 2005 at 08:17:39am
It is correct assuming that the volumetric efficiency is 100% which it VERY rarely is without forced induction. Edited by Vegard on 17th Jul, 2005. On 13th Jul, 2012 Ben H said:
17th Jul, 2005 at 09:15:09am
you also hjave to bare in mind the overlap of the cam you are using as well. as vegard said its all to due with ve.
