| Home > Help Needed / General Tech Chat > Adjustable Dump Valve | |||||||
31 Posts Member #: 330 Member Aberdeenshire |
14th Jul, 2005 at 09:25:47am
Hopefully someone can help me. I have acquired an adjustable piston type dump valve and was wondering how to set it up. It came with a spare stonger spring and screw down rod with locknut to adjust the preload but I have absolutely no idea how I should be going about setting it up. I have a modified plenum and I know the top connection goes to the inlet manifold or anywhere downstream of the carb butterfly but that?s the end of my knowledge. Any help much appreciated. |
14th Jul, 2005 at 10:50:23am
adjustable ???
14th Jul, 2005 at 11:20:21am
Cheers Ben. When you say vacuum you mean at idle? Please pardon my ignorance on this but the dump valve came into my possesion too cheap to turn down.
14th Jul, 2005 at 12:23:27pm
idle yes
18th Jul, 2005 at 12:57:04pm
Been having a wee think about this. Does all that mean that the dump valve is fully open when the engine is idling? If so is that in effect bypassing the air filter when on idle? |
18th Jul, 2005 at 02:53:19pm
yes. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jul, 2005 at 03:16:51pm
Cheers. Thanks for your help lads.
