Home > Help Needed / General Tech Chat > idler gear bearings
wng691s clubby
Member #: 9252
Cleethorpes
maybe a daft question but are both the idler gear bearings the same size gearbox and transfercase as somerford mini has them listed as slightly different for the A+
Done now needs redoing lol
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i believe there are small and big bearing sizes regarding the early and late a or a+ check your housing/drop gear
wng691s clubby
Member #: 9252
Cleethorpes
its not the a+ a- i was querying it was thee tranfer and gearbox is the same bearing used in each
Yes but only if they are both a or a+ iirc the a had larger bearings? I dont think you can interchange the box / drop housings or the idler wont fit
That said though i have never used A anthing so might be wrong
wng691s clubby
Member #: 9252
Cleethorpes
might be a typo on there site then, cheers guys just making double checking
Edited by wng691s clubby on 19th Aug, 2013.
Once upon a time there were only the small idler bearings. Then along came the A+ and were given the large idler bearings. If that wasn't comfusing enough, someone decided to make a larger bearing with a smaller hole.
I suspect the latter is the bearing you are getting confused with. This bearing is for use with a pre A+ idler gear in an A+casing, so it has the smaller pre A+ hole and the larger A+ outside diameter.
simples
