| Home > General Chat > converting the hif44 | |||||||
![]() 84 Posts Member #: 10419 Advanced Member |
19th Aug, 2013 at 04:31:09pm
I have a N/a hif44, and i belive i can get a kit to convert it to turbo from mini spares, now if i convert it to a turbo carb can i still run it NA with the end goal of eventually getting my project off the ground... |
1170 Posts Member #: 8636 Post Whore Surrey |
19th Aug, 2013 at 05:57:17pm
why not just leave it n/a until you go turbo? Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
19th Aug, 2013 at 06:20:01pm
WOW, Mind blown, apparently im a little slow on mondays |
19th Aug, 2013 at 08:06:23pm
19th Aug, 2013 at 08:54:07pm
You can turbo an na carb without modifications to the carb itself Yes i moved to the darkside |
20th Aug, 2013 at 02:41:37pm
oh? I thought you needed the o-rings to seal in the pressure? well that is good new saves me a bundle on parts i thought I needed. only 44 quid but where i am thats $70 plus shipping across the atlantic. so good to know still need to ship some parts. unfortunatly |
20th Aug, 2013 at 05:35:15pm
What about in n/a form when its sealing in the vacuum?
20th Aug, 2013 at 05:36:25pm
And the o ring is fitted in the carb body anyway so a turbo o ring wouldnt fit without machining on the na carb body Yes i moved to the darkside |
