| Home > Help Needed / General Tech Chat > Difficulty getting 1st and 2nd after a blast | |||||||
20th Aug, 2013 at 09:43:20pm
In the 13's at last!.. Just |
20th Aug, 2013 at 10:08:32pm
could ... maybe a master cylinder getting ready to crap out ? gary
20th Aug, 2013 at 10:35:27pm
Master cylinder to slave cylinder hose routed close to turbo elbow or thereabouts. -MINI CLUBMAN 1380 TURBO- |
21st Aug, 2013 at 06:10:04am
Flux Capacitor? On 11th Feb, 2015 robert said:
21st Aug, 2013 at 06:37:43am
On 20th Aug, 2013 T3Tone said:
Master cylinder to slave cylinder hose routed close to turbo elbow or thereabouts. This is what I'm thinking. I'll change the fluid too. In the 13's at last!.. Just |
21st Aug, 2013 at 06:38:33am
On 21st Aug, 2013 apbellamy said:
Flux Capacitor? This isn't what I was thinking. In the 13's at last!.. Just |
21st Aug, 2013 at 06:48:18am
You'll never sort it unless you start thinking outside the box. On 11th Feb, 2015 robert said:
1170 Posts Member #: 8636 Post Whore Surrey |
21st Aug, 2013 at 08:38:13am
http://www.youtube.com/watch?v=iodBPqN7vmk
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
21st Aug, 2013 at 09:07:09am
On 21st Aug, 2013 theoneeyedlizard said:
I'll change the fluid too. Definitely, if it is old and has absorbed moisture, the heat soak from the run could cause vapour bubbles which go as it cools down. Also I'd suggest using dot 4 rather than dot 3, not usually necessary for the clutch but it has a higher boiling temperature (with or without water absorption). Schrödinger's cat - so which one am I ??? |
21st Aug, 2013 at 09:15:25am
I think it had dot 4 in at the moment Rod. It's been in there around 2-3 years.
21st Aug, 2013 at 09:17:02am
change the fluid and sleeve the hoses in heat shield stuff. If something is worth doing, it's worth doing half of. |
21st Aug, 2013 at 07:16:37pm
Ok. Hose is miles away from any heat.
21st Aug, 2013 at 11:02:03pm
Yes the master cylinder is GOOSED, fit a new one and throw the other over the hedge,
22nd Aug, 2013 at 06:41:53am
This my chance to bin the servo I think.
22nd Aug, 2013 at 08:13:21am
Good plan. On 11th Feb, 2015 robert said:
22nd Aug, 2013 at 09:18:51am
servos are for the weak lol think of the weight saving |
