Home > Beginners Tech > Escort t3
Baz_rsp
Member #: 10521
Aberdeen
Basically iv got a few escort t3's and was wondering if I could fit the to my mini? Actuator the lot? I've done a search but never got a yes or no just lots of info about swapping compressors.
Flat oot like a dukes fit!
wng691s clubby
Member #: 9252
Cleethorpes
yes you can
Done now needs redoing lol
The main difference is the Escort one has an exhaust housing A/R of 0.36 compared to the Metro's 0.25 (although a reconditioned Metro one might also be 0.36 as the 0.25 housings have been NLA for a long time).
A 0.36 will spool up later than a 0.25 one because of the engine's smaller cc compared to the Escort (but the absolute maximum power could be slightly more if you are going for absolute maximum and don't mind it taking a bit longer).
Baz_rsp
Member #: 10521
Aberdeen
Don't mind a bit of lag as long as you get a kick in the back after. Lol. Thanks for that as I have a good rs turbo I can use.
welshdan
Member #: 1111
s wales
It wont go straight on. You need to use the metro wastegate, and possibly clock the unit so that the oil drain sits in the correct position. You also have to use the metro downpipe elbow and make an actuator bracket. I also had to modify the wastegate pin to get the actuator rod it fit it properly. Many thanks
welshdan
Member #: 1111
s wales
The escort turbo also has a larger compressor wheel so the escort compressor cover needs to be used
Baz_rsp
Member #: 10521
Aberdeen
Why can't you use the escort wastegate/ turbine housing and elbow? I was just thinking of getting a exhaust made to fit the rs elbow.
That would work. You still may need to clock the turbo to ensure the oil feed/drain orientation if acceptable.
welshdan
Member #: 1111
s wales
from the top of my head the wastgate /downpipe elbow are integral to eachother on the rs spec t3. if you try to use this the downpipe will be sticking through the bonnet. cheers, dan
sounds good to me *happy*
