Home > General Chat > std valve sizes?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Is this right?
MG Metro inlet 35.5 ex 29.4
mg turbo inlet 33.3 ex 29.4
I sure do hope so!
alex
AlexF
andeh
Member #: 97
Near Daventry, midlands
im certain all the valve sizes are correct appart from the turbo exhaust valve, im not sure if it wasnt a little bigger *oh well*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
right
they are correct but some mg metro heads have exactly the same size valves as the turbo head.
The sculpted areas around the rocker cover, thermostat and heater tap can be the same too.
So the only way to tell seems to be:
exh valve stems are about 8mm not 7mm like the inlets and all other mg heads.
The bypass hose is blocked off with a screw on mg heads and none-existant on turbo heads (ie that area is blank/smooth).
alex
AlexF
