Home > Technical Chat > Spax Coilovers
Bigchrismac10
Member #: 10501
Swadlincote
Has anyone fitted spax coilovers? Mine had a set on when I bought it ive just stripped it down to fit a neg camber kit. When I removed the front top mounting brackets I noticed 1 bolt each side was bent! Not good! It seems the holes in the bracket are to big for the 1/4 unf bolts so the bracket can actually move (and has hence the bent bolts!) I checked with mini spares and the part number on the bracket is correct and the same as the kits they sell (0760006 LH and 07 RH) I'm thinking of welding a plate to the inner wing with smaller holes in to stop the bracket moving then spot welding the bracket to the plate. Then using one or two of the top holes on the bracket to bolt 5/8 unf bolts straight through to the inner wing engine bay side with a second plate welded on there for extra rigidity.
Another option would be to fabricate some collars for the bolts to over size them to fit the holes but I don't have access to a lave. I would expect a kit from spax that cost over £700 to fit better or am I missing something here?
Any ideas?
Spax have bumoed there price for the coilovers recently, used to be £489 for a set with brackets now 770.... still same units!
As for the bolts, and bracket holes, my protech brackets are the same hole size as the std shock mount. Worth checking on yours and what grade the bolts are.
mini.cooper998
Member #: 3772
Wigan
Was a set on ebay for 299 last week. New
http://item.mobileweb.ebay.co.uk/viewitem?...Id=181014094225
Was rear only thoes new ones *wink*
